Go to Post There are no guarentees in life. Cherish what you have while you have it. None of us knows what tomorrow will bring. - KenWittlief [more]
Unread 21-01-2011, 21:22
mv2112's Avatar
mv2112 mv2112 is offline
Derpologist
AKA: Mike
FRC #3044 (0xBE4)
mv2112 is an unknown quantity at this point
CAN + Old Image are not allowing a reimage
When we tryed to reimage our cRIO it says this:
The imaging tool has detected that you have a CAN plugin enabled and you have an old image installed. Your cRIO would hang when trying to reboot. Please remove the CAN plugin from the StartupDlls line in ni-rt.ini and then manually reboot your cRIO before trying again.
How can we fix this???
Unread 21-01-2011, 23:26
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: CAN + Old Image are not allowing a reimage
ftp into your cRIO (user and password can be blank I believe) and edit ni-rt.ini (may be in /ni-rt, I don't remember). Look for the line with StartupDlls, and near the end of the line you should find an entry with either 2CANPlugin.out or BlackJagBridgePlugin.out. Remove it and re-upload the edited ni-rt.ini to the cRIO and try the imaging again.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 22-01-2011, 03:49
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The imaging tool is detecting a condition what would prevent it from working. Follow its instructions. It's trying to help you out. If you weren't the one who enabled CAN on your controller, then try asking that person to take care of removing what they did.
-Joe
Unread 22-01-2011, 04:03
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Radical PI has the correct solution. We had this exact same problem, and did exactly what he is describing and it fixed the problem.
The problem with doing what the message says (which essentially what Radical Pi recommends) is figuring out where the ni_rt.ini is located. The message does not give you any idea where it is or how to get at it.
It can be quite daunting if you have no idea where the file that needs to be edited is located. NI should have included location information in the error message at the minimum.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 22-01-2011, 04:11
That's probably true. I should have included the path to the file. I guess I was in the mindset that the person who added would be the person removing it and would therefore know exactly what to do. Clearly that is not the case. Perhaps a future version will be more clear (although this is a rather temporary feature since once everyone is running v25 or newer, it's a non-issue).
-Joe
Unread 22-01-2011, 09:35
mv2112's Avatar
Derpologist
AKA: Mike
FRC #3044 (0xBE4)
It worked!
Thanks
