Go to Post Want the TL;DR of it? Keep it simple, effective, and easy to use. - Andrew Schreiber [more]
Unread 22-01-2011, 02:38
Seathan93 Seathan93 is offline
AKA: Ian
FRC #1389 (The Body Electric)
Seathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to all
Mecanum Wheel Control
So I've gotten into a debate with my co-captain about how to control a Mecanum Drive system.
He thinks 1 joystick for driving around will be very intuitive, and therefore better.
I think, while not quite as intuitive, 2 joysticks will end up being better because there's more option for control and with practice, just as easy to control.
Neither of us have built mecanum drive before and I was wondering if any teams who have could lend some insight from their experience.
Thanks in advance.
Unread 22-01-2011, 02:55
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Mecanum Wheel Control
Some teams use one 3 axis joystick (x,y,twist). Others use 2 joysticks (one for translation, other for rotation.
2022 used 2 joysticks last year on an Xbox controller. The left stick was for translation, the right was for rotation, and the triggers were for turbo mode. It resulted in a very intuitive driving style with very high fidelity.
I know I would personally prefer the 2 stick method, simply because whenever I move a 3 axis joystick around, it always twists a little bit.
Unread 22-01-2011, 08:45
Program it so several ways are available, selected by the operator. Let the best scheme emerge. You need to turn driver input into translation/rotation commands anyway, so it's just a set of different transformations from which to choose.
Unread 22-01-2011, 08:54
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Thanks in advance.
If you know who's driving your robot, ask them what they want. It's not so much about what makes sense for everyone on the team, it's about what the driver thinks is easiest.
