Go to Post I wouldn't want to replay Lunacy -- the Moon is a harsh mistress! - Richard Wallace [more]
Unread 21-01-2011, 15:20
Chomper2013's Avatar
Chomper2013 Chomper2013 is offline
Team 1672 President
AKA: Katie Clarke
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Student
Chomper2013 is on a distinguished road
How many Jaguars...
Is there a certain number of jaguars allowed on the robot, or is it just sticking with budget and weight requirements?
Unread 21-01-2011, 15:44
Re: How many Jaguars...
The maximum is 20 simply due to the max number of PWM outputs available.
Unread 21-01-2011, 16:27
I almost answered the same thing, but then I remembered about CAN control.
Unread 21-01-2011, 16:31
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
You aren't limited, but you may wish to reconsider your design if you have 10+ speed controllers.
Unread 21-01-2011, 16:41
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
The highest CAN ID that WPILib can address is 63. However there are only 20 connectors on the PD board so that would limit you first.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Slaps forehead
But John saves me with his answer.
We should add this to the "How many Spikes" thread.
As many decorative Jaguars as you like...
Unread 21-01-2011, 17:57
sitzikbs sitzikbs is offline
FRC #3316
sitzikbs will become famous soon enough
does anyone havea link to the jaguars specifications + wiring info ?
Unread 21-01-2011, 18:25
Polaris395's Avatar
Polaris395 Polaris395 is offline
FRC #2537
Polaris395 is an unknown quantity at this point
Product specs available for download.
http://www.luminarymicro.com/products/mdl_bdc.html
That is for GREY jags. It you own the black version, they have a link to the spec page for them as well.
Unread 21-01-2011, 18:44
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Be careful regarding that. Joe Herschberger from NI can answer this better than I can, however I've heard that there may be a limit on the number of jags due to the bandwidth of the serial port. The folks from CrossTheRoad Electronics can also probably answer this as they've delved into it developing the 2Can.
If you're going to have quite a few speed controllers, I'd find out what issues it might cause.
We've run up to 6 with no issues.
Unread 22-01-2011, 02:04
G33K's Avatar
G33K G33K is offline
Professional Baller
AKA: Ethan Anderson
FRC #0100 (The Wildhats)
Team Role: Electrical
G33K is on a distinguished road
I believe there are only 8 40-amp capable connectors on the PD board, so that's another limiting factor. Not sure what size breaker the larger BaneBots motors require, but I know the CIMs for sure require a 40A circuit breaker. Also, the main breaker/power switch is rated at 120A, so think about that as well.
Unread 22-01-2011, 02:48
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
The Black Jaguar datasheet says 16 is the maximum.
I haven't had a chance to test more than 9.
-- Marshal Horn
Unread 22-01-2011, 08:47
Is no one going to mention the cost limits?
Unread 22-01-2011, 08:55
Budget and weight were mentioned in the original post.
