Go to Post "What's this on the floor? 'Team 71 2005 strategy and design notebook'?" DRAT! I better call Bill and get this in the mail. - Gary Dillard [more]
Unread 22-01-2011, 09:22
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
[FTC]: FCS Connection Question
Hey all,
So we set up our Ad Hoc network and the robots connect to it just fine. However, when we are in the FCS software and have added them to a match, we get: Not Connected to 3971 at 169.254.93.199.
Any help is appreciated... Thanks!
Tim
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 22-01-2011, 09:26
Tim Delles's Avatar
Since 2001.
FRC #0078
Re: [FTC]: FCS Connection Question
An update to this.
If we wait about 1 minute after Samantha is powered, it connects to the FCS and looks normal. But when you start a match, the Samantha dies.... aka it stops responding and seems like it powers down.
Unread 22-01-2011, 17:56
Techhexium Techhexium is offline
FTC #3555
Techhexium has a spectacular aura aboutTechhexium has a spectacular aura about
When the Wi-Fi module dies, or rather drops its connection, does the motors or servos continue to run? When the connection is dropped, the NXT will repeat the block the code it currently is in (only in RobotC, I don't think it happens in LabView).
If this happens and you aren't running a program, then 1) your external battery may not have enough power, or 2) the router the module is trying to connect is bad, too far away, or there is too much interference present, like computers connected to the Internet thru the router. Finally make sure your module is connected correctly, and update your FCS to version 2.0 if you haven't. Anyway, for some reason whenever my team tests out the FCS the module would always drop the connection, but in the competition it work fine, except for a couple occasions.
http://usfirst.org/uploadedFiles/Com..._Practices.pdf
