Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 01-22-2011, 11:14 AM
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: FRC Vision Undeclared Functions
To start streaming video to the classmate all you have to do is get an instance of the AxisCamera object. If you look at the implementation of AxisCamera::GetInstance() and trace the functions it calls you will see it automatically sets up a pc video server object and starts it up. Assuming you had a class named LogoVision that inherited from SimpleRobot the following code would be enough to start streaming video to your classmate once you entered autonomous mode. The api's you mentioned are at a lower level than you need to be at.
void LogoVision::Autonomous()
	AxisCamera& camera = AxisCamera::GetInstance();
	while(IsAutonomous())
