Go to Post If I can do it, it's not art. - Ether [more]
Unread 22-01-2011, 11:20
Arnie365 Arnie365 is offline
FRC #2526
Arnie365 is an unknown quantity at this point
LabVeiw Code Deployment
Ok so I am trying to put code on to the cRIO and use the classmate as the driverstation.
In labView in the project manager I go to build dependecies and right click and click on "run as startup" and then it tells me that it completed the process and then I need to reboot the cRIO and I allow the computer to do it. I then plug in the classmate and it gets communication with the cRIO, but it tells me that no code is detected. Did I do some thing wrong?
Unread 22-01-2011, 12:40
NewbPwner NewbPwner is offline
Junior Member
NewbPwner is an unknown quantity at this point
Re: LabVeiw Code Deployment
First thing i would do is to open up labView and open your project. Go to the "File" menu and hit the button that says debug. A popup should appear asking if you want to debug your code. Click yes and a status bar will appear on the screen. After it completes, retry the connection.
Unread 23-01-2011, 01:44
Before you chose "Run as Startup", did you first "Build" the project?
Unread 23-01-2011, 02:22
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
we're having the same problem.. the exact same thing as you except ours is showing code but when we start teleop or autonomous.. nothing happens! it'll run but our joysticks and buttons do nada
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 23-01-2011, 15:08
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Build project
Run as startup
Reboot does not seem to work that well from labview
Reboot from the driver station under diagnostics tab (I think)
Wait for a few until you get communication and Robot Code
Hope this helps
Unread 23-01-2011, 17:47
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
also, make sure you read the dialog box during deployment. If, when it's finished and waits for you to click a button (i forget which), it says "deployment completed with errors" then it didn't work. Simplest troubleshooting for this would be cold reseting the cRIo and trying again.
