Re: Iiko problems.
Ah, I have had that problem...what you do is you go into edit envelopes for the bone you want to edit, select the verticies you want to remove, go down to Abs. Effect and type '0', then go to the "Exclude Selected Verts" button (face with a slash through it) and press it. That should work.
Re: Iiko problems.
Sorry this took so long, but I'm new to Maya and I dont really know what that means lol, can you like.. Explain how to do get to that?
Re: Iiko problems.
How do you re-size the iiko?
Re: Iiko problems.
I have a question.
So the iiko doesn't import into maya properly, the geometry transfers but the movement doesn't (I don't really know technical terms). I know how to make joints, but I'm not sure how to connect them to the body... |
Re: Iiko problems.
HELP!!!
does anyone know why I can't open the Iiko Kit in either 3ds and maya... Last edited by KyrieEleison : 30-01-2011 at 12:02. |
Re: Iiko problems.
did you unzip the iiko file?
