Go to Post I can't believe that I said the CD community could be patient - in December. - JaneYoung [more]
Unread 19-01-2011, 14:33
Valencia Valencia is offline
FRC #3705
Valencia is an unknown quantity at this point
how to setup the encoder?
How would you setup the encoder and place it in the robots
and how would it work?
Unread 19-01-2011, 15:55
Re: how to setup the encoder?
To which encoder are you referring?
Unread 22-01-2011, 15:00
FRC #3705
How do you set up the US Digital E4P encoder? We also need the sample program in C++ to control the encoder.
Unread 23-01-2011, 01:50
Are you asking about mounting it mechanically, or about connecting it electrically?
Electrically, it has four wires. The "A" signal, +5, and GND go to one DIO connector on the Digital Sidecar; "B" goes to the SIGnal pin on another DIO connector.
