Go to Post To the people in purple - I am so proud of what you have accomplished as individuals and as a team! - Ken Patton [more]
Unread 22-01-2011, 19:55
9lives11 9lives11 is offline
Rox ur sox :P
AKA: Fawn
FRC #1547 (1547 Where's Waldo)
9lives11 is an unknown quantity at this point
Air Cylinder Questons
I have a few questions about the pneumatics and air cylinders hope you can answer.
The following questions apply to competition use and we have been unable to find the answers in the rules.
1. Are SMC Cylinders able to be used in replacement to Bimba cylinders?
2. Are rod lock cylinders allowed?
3. Are cylindicators or reed switch indicators allowed?
4. What other regulations limit use to pneumatic systems
5. Are accumulators required in pneumatics systems?
Go Where's Waldo! (Team 1547)
http://www.google.ca/imgres?imgurl=h...w=1280&bih=675
Unread 22-01-2011, 20:13
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
Re: Air Cylinder Questons
This year they have less restrictions on the pneumatics. My understanding is that you can use any cylinder or storage tank as long as it has a working pressure rating of at least 125 PSI and a burst pressure rating of 250 PSI there is no Bore or Stroke limits. How ever this year you are only allowed one solenoid to power any particular cylinder.
Reed switches are allowed, my team used some last year, and accumulator tanks are not required, but I would recommend using them.
Hope this helps.
Unread 22-01-2011, 23:00
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
only one solenoid per cylinder!? so no cutting off of the exhaust air?
Spartans, Prepare for GLORY!
Unread 30-01-2011, 18:39
Sandvich's Avatar
Sandvich Sandvich is offline
NOM NOM NOM
AKA: Kyle
FRC #0696 (The Circuit Breakers)
Sandvich is on a distinguished road
What? Why? Where is that stated?
Unread 30-01-2011, 18:51
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
<R74> Each commanded motion of a pneumatic cylinder or rotary actuator must be accomplished via the flow of compressed air through only one approved pneumatic valve. Plumbing the outputs from multiple valves together into the same input on a pneumatic cylinder is prohibited.
This rule does not prevent you from having a solenoid valve on each input only limit is one per input.
Unread 02-02-2011, 22:36
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
The purpose of this rule is so we don't gang multiple solenoid valves together and fire them at the same time to increase the flow to a single cylinder.
Unread 02-02-2011, 22:39
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
This is the way i take it in!
Unread 02-02-2011, 22:49
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
YES
I do not know but I suspect that is ok. They are standard off theshelf items so is should be OK.
YES
4. What other regulations limit use to pneumatic systems?
Read the manual.
No, but it is a very inportant part of a pneumatic system.
