Go to Post Here's some food for thought: Does your FRC program need the students, or do the students need your FRC program? - sanddrag [more]
Unread 22-01-2011, 20:56
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Line Tracking Photoswitch Info and Demo Video
Info gathered from other threads for one stop shopping.
Brown +
Blue -
White (sig) to digital side car
Black nothing
If the Sensor is Green: Sensor is powered but does not sense reflection. no output on blk or wht.
If sensor is Orange: ON sensor is recieving at least 2.5 times the signal strength needed to trigger an output and green will turn off. May have to adjust the sensitivity adjustment on top of the sensor to get an orange on if already mounted. Do this by placing over reflective surface and adjust until it comes on. Sensitivity is the screw on top. If orange is not on there will be no output on blk or wht.
If sensor is Yellow: the output has been energized meaning it sensed a reflective object. be careful most bright objects can be sensed regardless of color.
Typical sensor indication is the following
Green ON, Orange OFF, Yellow OFF over dull none reflective surface wht low and blk high
Green OFF, Orange ON and Yellow ON over bright reflective surface wht high and blk low
If you have a flashing LEDs, the sensor has gone in to short circuit protection mode becasue one of the outputs is shorted to ground or it is not wired up correctly. Make sure the black wire is not connected ianything. Make sure the white is connected to the signal pin on the digital side car pwm input and not the + or -. Best way to prevent the shorting out of the black wire is to clip the stripped wire and then wrap it with electrical tape. Inspect the sensor cable for any nicks. I will try and post a quick video by the end of today to show how it works and how to connect it.
Demo 1 01-22-2011
http://www.youtube.com/watch?v=t7pf-yWae0k
Demo 2 01-22-2011
http://www.youtube.com/watch?v=algLRT4Tawc
Hope this helps...
Name:	Photoswitch connection.jpg
Unread 23-01-2011, 12:32
Belly's Avatar
Belly Belly is offline
FRC #1340
Belly is an unknown quantity at this point
Re: Line Tracking Photoswitch Info and Demo Video
Hey do you have or know where I can get a working Java code for the Photoswitches? I have 3 of them connected to the DIO. I dont mind switching my hardware configuration to be compatible with yours if it is not already.
Narcisse- 1340
---The best inventions in life happened by accident---
Unread 23-01-2011, 21:04
riptide's Avatar
AKA: Jeff
I'm sorry Belly, but I don't. If I come across something I'll keep you in mind.
Unread 25-01-2011, 17:42
pigpc1993 pigpc1993 is offline
AKA: Colin Feeney
FRC #3716 (WARP)
pigpc1993 is an unknown quantity at this point
Narcisse- 1340
My programming team is also having trouble finding example code. If you find anything could you let us know two?
Unread 25-01-2011, 18:54
Narcisse- 1340
Did you look at the LineTracker Sample Project in netbeans?
Unread 27-01-2011, 18:51
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Ethan Spitz is an unknown quantity at this point
We have ours tracking the line as well with 2 or 3 sensors:
http://www.youtube.com/watch?feature...&v=PBG5g8geATw (3 sensors)
http://www.youtube.com/watch?v=06FPQ...er_profilepage (2 sensors)
Ethan
www.team3637.com FIRST team 3637's Website: The Daleks
Unread 29-01-2011, 18:24
wazcodez's Avatar
wazcodez wazcodez is offline
AKA: Megh Suthar
FRC #2076 (Blackscots)
wazcodez is infamous around these partswazcodez is infamous around these parts
Send a message via MSN to wazcodez
we can't get code working in labview ? does any one have custome code rather than .. default which is too hard to understand .. we are rookie
" When you copy from one source it's called plagiarism when u copy from multiple it's Research .. ! " - Megh Suthar
Unread 29-01-2011, 18:27
President
I would start out by making a handwritten flow chart saying what you want it to do when each sensor is triggered. For example, when the left sensor is triggered, make it go right, and when the right sensor is triggered, go left. When neither are triggered, go straight.
Just use nested case statements and use the DIO ins to be the input for the case statements
Ethan
Unread 29-01-2011, 20:39
wazcodez's Avatar
AKA: Megh Suthar
Ethan
Thanks for replying, should i control motor inside the nested loop or change the value for x or y inside the loop ? which will be sufficient enough and how do i know tht i have reached the "Y" part, i just started the programming ... ?
thanks for your help, will lwt you know if i have any problems ... thanks
Unread 29-01-2011, 20:41
President
I put the set output inside the loop because its less cluttered, but you could just put the value inside, that would work just as well.
You know it gets in there when the desired thing happens when you try it with the robot.
Unread 29-01-2011, 21:08
wazcodez's Avatar
AKA: Megh Suthar
i will follow your advise
tht's wht i did now ...
any suggestion and yea how do i make robot turn slowly !!!
thanks again
Unread 29-01-2011, 21:11
President
I seriously hope you're trying to be funny, becuase you have to put set motor output in there....
don't use the arcade drive module use the set motor output module
and to make it turn slowly, just use (to go right for example) right motor output at .1 and left motor output at .2 with them both going forward
Ethan
Unread 29-01-2011, 21:38
wazcodez's Avatar
AKA: Megh Suthar
Does this look proper ?
or beacuse of having arcade drive module, the value from (set motor output) would not matter, right ?
should i keep it like this ?
if tht's not the case then should i create new drive system (tank...) just for the autonomous and then switch it back to arcade ? OMG !!!
thanks man ! you have been greatly helpful
Unread 29-01-2011, 21:42
President
Ive never used the tank or arcade module so I wouldn't know
Should I assume you got it?
If so, congrats, and you're very welcome, feel free to message me or email me whenever you need help
Ethan
Unread 29-01-2011, 21:44
President
I do have one problem with your code however. You need to open everything up in your begin.vi or you are going to run into a lot of problems. Also make sure you close everything in your final.vi
Ethan
