Go to Post Remind me to wear my kevlar vest to any event you're at. - Andrew Schreiber [more]
Unread 22-01-2011, 08:36
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
2bkrul is an unknown quantity at this point
Camera picture rotation on LabVIEW
Is there any way to rotate the camera image on LabVIEW. Our camera is positioned on its side
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
Unread 22-01-2011, 08:52
Re: Camera picture rotation on LabVIEW
Vision->Vision Utilities->Image Manipulation->IMAQ Rotate
Unread 22-01-2011, 08:54
The Axis 206 camera itself has the ability to rotate its output, but only in 180 degree increments. I think the M1011 can do 90 degrees, but I'm not sure. Which one are you using?
Unread 22-01-2011, 08:59
You don't mention whether the rotation is for driver sanity or for processing, but as with any operation on images, pay attention to the CPU cost. If you want this for the dashboard, perhaps you should rotate it in the dashboard code so that the cRIO isn't involved. If the M1011 does support 90 degree increments, that is cool because it will be done in HW.
If it is being done for processing, you should be able to choose your coordinate system for operations such that it has no additional cost.
Greg McKaskle
Unread 22-01-2011, 12:03
2bkrul's Avatar
AKA: Brandon Krul
We are using the Axis 206. How would i rotate the output?
Team 964 on TBA!
Unread 22-01-2011, 22:05
There is a camera property for camera rotation, but it apparently didn't make it into the interface. If you log into the camera or use vision assistant, you can set the angle, but on the 206, it is definitely either 0 or 180.
Greg McKaskle
