Go to Post We will be stressed, we will be angry. But we need to hold ourselves to a higher standard, we need to be role models and inspirations to students. - Andrew Schreiber [more]
Unread 22-01-2011, 18:40
brian3795 brian3795 is offline
FRC #3795
brian3795 can only hope to improve
Practice bots: OK with rules/spirit of competition?
Rookie team here, still trying to sort things out. One of our mentors proposed an intriguing idea: Build a "practice bot" almost identical to our primary bot to give us something to practice with during the month of downtime between the robot ship date and competition.
We found nothing explicitly prohibiting this in the rules. Is this something that other teams routinely do? (Still waiting for our "mentor" team to be assigned...actually, we've pretty much given up on that happening!)
Unread 22-01-2011, 18:44
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: Practice bots: OK with rules/spirit of competition?
100% perfectly legal!! Many teams do this, to play with and learn from... Plus it's great for driver practice!
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 22-01-2011, 18:45
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
One thing you have to consider: resources. Do you have to money, time, manpower to build a second robot? Its not prohibited in any way, but considering the fact that you only have 6 weeks and a limited budget, its almost impossible to have a decent robot for the competition while making a practice robot. Unless you are making the practice bot just a chassis with wheels. Especially being a rookie team. While most veteran teams have robots from previous years, most rookie teams do not have that luxury.
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
The majority of the more successful teams build practice robots. The teams I have been involved with the past 3 years have built practice robot and the help has been absolutely immense. If at all possible and it won't compromise other things then definitely build a practice bot.
Mentor 2415
Unread 22-01-2011, 18:55
FRC #3795
Good point. We will probably have the resources for a practice bot, and we don't plan on building the second one concurrently. We'll just do our best to document what we have before we ship.
Now that we know the option is open, we can start planning for this.
Unread 22-01-2011, 19:01
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
If you have the resources, you will probably find there is a real benefit to building a "practice robot" first and then use your design and lessons learned from that first one to build a second, competition robot.
The second one goes together much faster, and the electronics team, programmers and drivers have the first one to work and learn on.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 22-01-2011, 19:06
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
We build a practice bot with the "intention" of having it done by week 2 (most of the time we more likely see iy by week 3 or 4) and then build the final robot afterwards improving on what was learned from building the first robot.
It all depends on the time and resources you have to build it but I would highly reccomend you do it. It is a valuble resource to have for your drives team.
Unread 22-01-2011, 19:40
pfreivald's Avatar
AKA: Patrick Freivald
We are building two -- one for competition, the other 'close enough' (because of cost issues in building two that are truly identical).
It is important to make the 'close enough' robot controlled exactly the same way as the competition robot -- and as close as possible mechanically as well.
...and while part of me envies the month between bag-n-tag and your first regional, part of me is very glad that FLR is week one!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Even if you cannot make another full robot due to time, materials, money, etc having just a chassis is still worthwhile. It allows for driver practice among other things. If you can practice even for 3 hours (I mean actual drills, not just driving around) you will have more experience then most teams by the end of their season. That is a HUGE advantage!
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 22-01-2011, 22:35
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
We only have one Classmate this year and are working on a practice bot. Is there a way to run both robots, alternating? We also have only one wireless access point.
Thanks for any pointers!
Unread 22-01-2011, 23:08
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Could you try and find someone willing to donate or sell an old laptop at the least and install the Driver Station software on it so you have another Driver Station.
For the router problem I am afraid you probably will have to try and get another one. The robot is suppose to have a certain IP address in the network, you can't have both of them with the same address in the same network.
Unread 22-01-2011, 23:20
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
By my count (Assuming they haven't broken their old ones) they should have 3. The Linksys DS radio from 2009, the Linksys gaming bridge from 2009, and the new bridge/radio from 2011.
There are two options for setup on this:
1. Run each as its own network. This would require two DS computers (including your Classmate, so you just need to find another one). You would run the practice bot using the pair of 2009 radios and the extra laptop, and the competition bot using the new 2011 radio and the Classmate. You would need two sets of driver controls as well, which might not be easy if you use the Cypress board.
2. Run one as a different team. Pick a team you like, or another number you won't forget. Image the practice bot as so, and setup the second laptop and old radios as well. In LabVIEW, you could create a new build specification for practice, which would just change the robot IP.
Or you could just not use them both at once. If you need to run another robot against the practice bot (maybe a boxbot or a kitbot or something for driver anti-defensive training?) you could just use an IFI control system. You wouldn't even need to program it (gotta love default code).
Kettering Motorsports
Unread 22-01-2011, 23:44
Thanks for the suggestions everyone! I'll pass along the suggestions to our software team.
I'm personally thrilled that this is our third year and we've finally gotten to the point that we'll be able to test and do driver training.
Unread 23-01-2011, 00:39
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Perfectly fine but I would like to share a bit of adbice:
1. Don't starve yourselves of resources to get the second bot done. Make sure you can build one good bot first.
2. The practice bot is for practice. After the main bot ships, you must keep the practice bot as close to the real one as possible, because that's what you'll have to work with at the competition.
I've witnessed what happens when you try to use a "practice bot" along with the withholding allowance to make the six week build season a nine week build season. It doesn't work at all.
Go directly to queue. Do not pass pit.
Unread 23-01-2011, 12:33
techedguy's Avatar
techedguy techedguy is offline
Technology Education, PFHS
AKA: Sal
FRC #4520 (Roboteknix)
techedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nice
We've been using an older control system on the kitbot for programming practice, sensors, ect. We are working on making the control system swappable between chassis and using the KOP chassis for practice and a "real" chassis for competition. Of course once the 'bot ships we'll have the KOP chassis to practice with. (which just thinking it through means I need to order more sensors...)
Salvatore Lorenzen, M.Ed, Ed.S.
Mentor/Coach/Teacher
I am not who I hope to be, but I am trying. I am giving it my all to improve me; and I’m thankful at the end of each day that I’m not the guy I used to be.
FRC #4520 - Misfit Toys
2012 Spokane Regional WFA
2009 Idaho GIANTS Award
