Go to Post The evil Chief Delphi machine will begin to consume you and your non-robotics life thread by thread. First hand experience :D. - frcguy [more]
Unread 22-01-2011, 12:23
Darknight1243 Darknight1243 is offline
Darknight1243
AKA: David V.
FRC #3172 (SCRobotics)
Darknight1243 is an unknown quantity at this point
Minibot- activation
What can you use/not use to activate your minibot, like I was thinking of using these limit switches we got from last year which, when activated, will cut power/signal to things like arms and kickers. My idea was to use the same idea only reverse, meaning when the switch is tripped the 'bots code would activate. Does anyone know if this would be a viable method?
Unread 22-01-2011, 22:04
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Minibot- activation
Minibot builders need to print out the rules governing minibot construction, especially the rule that lists allowable parts. Make a copy for each member of your minibot sub-team, make another copy for the box of parts you have collected as having potential use for your minibot. Make more copies for those sub-team members who will claim to have forgotten them at your next meeting. Make one for yourself, laminate it, hang it on a lanyard around your neck in the manner you sometimes see football defensive and offensive coordinators do on the sidelines.
These and other actions will help convince your team members that the rules are important and also shorten your design cycles considerably.
As for your question - the switch you mention doesn't appear on my copy of the rules, so I doubt you can use it.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 22-01-2011, 22:38
GaryVoshol's Avatar
Cogito ergo arbitro
<R92-M>?
(since 2004)
Unread 22-01-2011, 23:10
FRC #2170
Originally Posted by GaryVoshol View Post
<R92-M>?
I sit corrected - and am shredding my rules copy that has failed me miserably.
My guess is that I had already dismissed limit switches as not being able (usually) to handle the motor currents. However, the Honeywell spec. sheet this year shows 11A rating, and such a tiny thing it is too.
Thanks Gary and "Dark". Good thing it's so far to ship date.
Unread 22-01-2011, 23:37
Bsteckler's Avatar
Bsteckler Bsteckler is offline
Resident computer tech
FRC #2402 (JamesMonroebotics)
Bsteckler has a spectacular aura aboutBsteckler has a spectacular aura about
How about a light switch? you can use up to two of those.
"Don't try anything you are about to see us do at home, ever"
-The Mythbusters
2402 scores points.
Unread 22-01-2011, 23:50
FRC #2170
When I saw the household wall switches on the list, I related it directly to their inherent current carrying ability. I already had my eye on some neat rocker wall switches until I got shamed into reading the specifications for the limit switches. Maybe those little devils can do everything that needs to be done to control a minibot. Hard to beat the weight differential if they can.
Unread 23-01-2011, 01:14
Andy A. Andy A. is offline
Getting old
FRC #0095
For a maximum of 10 seconds, yeah, they can probably take whatever those little motors will ask from the battery.
Look carefully though. Switch current ratings are determined at a specific voltage and operating environment, and not all switches are created equal. Still, the rating applies to a steady state condition and you can safely exceed those ratings for short durations. Just continually check that the switch activates cleanly. These switches don't often fail catastrophically, but slowly become unreliable as their internal contacts get scorched and move around.
Unread 26-01-2011, 11:28
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Question Re: Minibot- activation
team 2905 :::: we thought like that we will run the program at the beginning of the match by our hands but the minibot will not do any action because we will put a touch sensor in last 20 seconds when the touch sensor will touch the pole motors will start to run ... is it possible
Unread 26-01-2011, 11:33
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We are using these. They're very cheap, work in the same manner as a bumper switch, and are lightweight. There will be 2 in series: The pole-bump switch will be "off" and the goal-bump switch will be "on". When we DEPLOY, the pole-bump switch will turn "on", completing the circuit and turning on our motors. When we get to the top, the goal-bump switch will turn "off", breaking the circuit and turning off the motors.
I'm sure we could do some fancy lever arm that can do both the pole-bump and goal-bump actions, yet simply adding another switch is simpler and about the same weight.
