Go to Post Tell the truth - that's really a small barbecue grill on that robot isn't it. - Tom Line [more]
Unread 22-01-2011, 23:20
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Practice bots: OK with rules/spirit of competition?
Originally Posted by ZonChau View Post
For the router problem I am afraid you probably will have to try and get another one. The robot is suppose to have a certain IP address in the network, you can't have both of them with the same address in the same network.
By my count (Assuming they haven't broken their old ones) they should have 3. The Linksys DS radio from 2009, the Linksys gaming bridge from 2009, and the new bridge/radio from 2011.
There are two options for setup on this:
1. Run each as its own network. This would require two DS computers (including your Classmate, so you just need to find another one). You would run the practice bot using the pair of 2009 radios and the extra laptop, and the competition bot using the new 2011 radio and the Classmate. You would need two sets of driver controls as well, which might not be easy if you use the Cypress board.
2. Run one as a different team. Pick a team you like, or another number you won't forget. Image the practice bot as so, and setup the second laptop and old radios as well. In LabVIEW, you could create a new build specification for practice, which would just change the robot IP.
Or you could just not use them both at once. If you need to run another robot against the practice bot (maybe a boxbot or a kitbot or something for driver anti-defensive training?) you could just use an IFI control system. You wouldn't even need to program it (gotta love default code).
Kettering Motorsports
Unread 22-01-2011, 23:44
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
Thanks for the suggestions everyone! I'll pass along the suggestions to our software team.
I'm personally thrilled that this is our third year and we've finally gotten to the point that we'll be able to test and do driver training.
