Go to Post the jocks may have muscle, but we have extruded aluminum :D - [527]phil [more]
Unread 22-01-2011, 23:23
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
Code built, robot somewhat connect.. but not running.. HELP!
So, today our team put a entire labview code together and a prototype of the robot and everything on it we'll be using.. good there.
We'll.. we go to hook it up and it wont connect wirelessly.. we'll check the bridge and router monday..
so now.. we do it by wire.. working great.. connected and everything.. deploy the code after building and were good to go.. turn on the robot.. it connects.. runs.. but.. push the joysticks.. WONT GOOO!
I forgot to take note of the driver station errors in the diagnostics.. anyone having this problem and find a solution? we also tried code examples from labview.. help us :/ we are imaged to the new v25 image
<edit> i found a few other things to fix in our code.. but anyone else still have any thoughts? </edit>
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 23-01-2011, 07:17
Re: Code built, robot somewhat connect.. but not running.. HELP!
You don't mention much about the driver station. Is your robot enabled? There may be DS issues that need to be resolved before you can enable. The other issue could be errors in Begin or in Teleop that are cause your motor updates to return an error.
Greg McKaskle
Unread 23-01-2011, 12:08
Team2057LasVegas
AKA: Justin Major
Greg McKaskle
I did remember when i got home i forgot to close my operations and put the safety vi's in the begin.. so i'll try that monday.. but what was happening was by wire it was enabled but the code wouldnt run.. a push of a button or joystick did nothing. we tried running a example code too and it didnt change anything.. so im hoping it wasnt any coding error.. ill write down the errors i get monday if my fix to the code doesnt change things
Justin Major
2057 Team Leader
Unread 26-01-2011, 18:25
U5ER NAM3's Avatar
U5ER NAM3 U5ER NAM3 is offline
AKA: Big Sexy
FRC #3312 (eaglebots)
U5ER NAM3 is an unknown quantity at this point
i need help on finding the set speed control in the while loop thing i can not find it at all
Unread 26-01-2011, 23:00
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
MattCarey3625 is an unknown quantity at this point
What do you mean by Set Speed? Do you mean Set Output for motor control? Why do you need the While loop constant? I believe I can help, I promise that I can do more than ask questions
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
Unread 27-01-2011, 01:01
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Look under the diagnostics tab, and if it doesn't show anything there, it's probably wiring. If there's something there, by all means post it!
