Go to Post Just wondering what types of food you have been living off of while working on your robot? Our team has had pizza almost 3-4 times a week or more. Just wondering. SGS DRAGONS - sgsdragons [more]
Unread 23-01-2011, 03:22
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Watch Dog stopping robot from working?
[quote=DavidGitz;1006228Since we are pulling the same reference (default "Left and Right Motors") and using Arcade on one mode and Tank on another mode that can be changed back and forth, could this result in the error noted above due to the Arcade/Tank difference?[/QUOTE]
No. If you open up the vis, it shows that the only difference is some processing of the joystick values before it runs the "runMotor" and "safetyupdate" vis.
Try adding a timer to see how fast the loops are running. To do this, add a tick count to your teleop.vi, then a feedback node. Connect the tick count to the input of the feedback node (on the arrow, not the diamond) and then add a subtraction command. Wire the output of the feedback node to the bottom of the subtraction command and the tick count to the top. Then put an indicator on the end of the subtraction command and look at it while the code is running.
Unread 23-01-2011, 07:50
You may want to look for a VI called Loop Time, Loop Timing, or something similar. It is a subVI you can drop into a loop, and since it is called each iteration, it will record info about the rate of the loop. You can then open the subVI at any point and peek at what has been going on.
Additionally, you can wire up a string to different calls in other loops, and instrument as many loops as you care to watch.
There is a small amount of overhead for having this in, and apparently they decided not to put this into the default framework, but it is very handy for issues like this.
Greg McKaskle
Unread 24-01-2011, 08:22
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
We had a the same problem and after killing ourselves trying to find the programing error we realized that all the PWMs were in backwards which was shorting out the digital sidecar. Double check the electrical work, especially if the default drive code is having problems too. Hope that helps.
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 24-01-2011, 09:28
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Wow. No that's not the problem.
Unread 24-01-2011, 21:30
I discovered that the loop timing info is described in the Troubleshooting link on the Getting Started window.
Greg McKaskle
Unread 27-01-2011, 16:29
xYinx161 xYinx161 is offline
FRC #1208
xYinx161 is an unknown quantity at this point
This is team 1208's time from an elapsed time function. With default code (on the right) the time is 40 miliseconds and with our code (on the left) it is on 90 miliseconds on average. We have also included our teleop.vi. Is this a problem and if so what can we do to fix this.
ID:	9844  Click image for larger version
Unread 27-01-2011, 17:25
U5ER NAM3's Avatar
U5ER NAM3 U5ER NAM3 is offline
AKA: Big Sexy
FRC #3312 (eaglebots)
U5ER NAM3 is an unknown quantity at this point
i need help on the motor control Set Speed icon but i cant find it so i cant finsh the while loop until i get the Set Speed icon can u help me?
Unread 27-01-2011, 22:30
If it's an average of 90ms, that will be a problem. It's right on the edge of the Safety vi timeout at 100ms and since it's an average nearly half will be beyond the tripping point.
I don't see anything obvious that's slowing you down, although it's easy to isolate the slowdown using Disable structures on the stand-alone blocks of code.
It looks like you are also setting your motors in two different places. Those two conflicting sets will be fighting for control of your robot when the time comes. You need a way to choose one or the other, not both at the same time.
The Arcade/Tank mixture shouldn't be a problem. They don't remember who was called last and they both reset the Safety vi.
