Go to Post If this doesn't show up in spotlight at some point I'm almost going to be sad. - Andrew Schreiber [more]
Unread 23-01-2011, 03:40
Team3390 Team3390 is offline
AKA: Ömercan Demiral
FRC #3390 (Anatolian EagleBots)
Team3390 is an unknown quantity at this point
How can I install LabView another Pc
How can I install FRC's LabView kit another compuer? I installed LabView but I couldn't install the FRC version. I'm waiting for your help.
Unread 23-01-2011, 04:18
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
Re: How can I install LabView another Pc
Did you install the FRC Utilities and LabVIEW update after you installed LabVIEW?
Here they are if you didn't
Unread 23-01-2011, 07:51
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
You should be able to install LabView on as many team computers as you want. Make sure you do it in this order though:
1) Using disc provided in KOP, install LabView. You will need the serial number to activate the product. This is in the KOP documentation.
2) Download FRC updates from http://www.usfirst.org/roboticsprogr....aspx?id=18758. Everyone must install the DriverStation updates and Utilities. Since you want to use LabView, download the LabView update as well.
3) On each computer you that installed LabView, install the three updates.
4) If using a different computer for the driver station that does not have LabView on it, you need to install only the first two updates.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 23-01-2011, 14:13
No, but I'm installing now. But I installed (without it updates) a Windows XP operating system but I can just see "LabView". I can't see any FRC options
Unread 23-01-2011, 14:43
The LabVIEW FRC options come in the LabVIEW Update.
the DVD only installs basic LabVIEW.
Unread 23-01-2011, 14:54
Yes, I made updates and it still not. I explained my remaining part of the problem
re:
http://www.chiefdelphi.com/forums/sh...ad.php?t=89883
