Go to Post Note to self for next year, apply physics rather than "well, this SEEMS like it would work." - Karibou [more]
Unread 23-01-2011, 10:13
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
6 wd, what wheels to power
In the 6 WD configuration, is it better to power all 6 wheels with a chain or would it be better to simply power the rear two with the chain? The middle wheel is dropped.
"Though I fly through the Valley of Death I shall fear no evil, for I am at 80,000 feet and climbing."
Unread 23-01-2011, 10:16
Billfred's Avatar
Billfred Billfred is offline
Re: 6 wd, what wheels to power
By powering all six wheels, 100% of your robot weight will be on driven wheels. This will, in most every case, improve your ability to push another robot.
(For more fun, you might want to spend a bit of time playing with JVN's excellent mechanical design calculator. While not a substitute for Really Knowing What You're Doing, it can find some interesting attributes of your planned design.)
Unread 23-01-2011, 10:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
In addition to what Billfred said, there is a big issue wit powering only the rear two. A 6WD drop can rock a bit between being on the front 4 wheels and the back 4 wheels. If you power only the rear 2 wheels when you rock to the front 4 you will not be able to drive very well at all (the others may still touch some and give you slight traction). If you were going to power any set of two it should be the middle, but I second the recommendation to power all of them.
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
With a drop center design, if you were only thinking of powering two wheels then it should be the center wheels as the rear wheels can leave the carpet. However, the whole point of 6WD is all six wheels are driven.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 23-01-2011, 10:31
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: 6 wd, what wheels to power
Just to add that you should chain from the motor to each wheel individually. If you lose a chain (or more), you will still be able to maneuver.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 23-01-2011, 10:53
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
We powered all six wheels; the KoP drive train has a dual sprocket at the transmission, so you can get two of the wheels on a side powered easily. (Just remember to swap the spacers on one of the axles, I'd recommend the non-middle one, so the sprockets align better.) Then all you'll need is a pair of sprockets and a loop of chain to reach between the middle and the other non-middle wheel.
The only other caveat is to make sure that the wheels powered directly from the transmission must have the same size wheel sprockets!
"It's NOT Just A Robot Thing!"
Unread 23-01-2011, 11:18
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
If you get a chance to watch the 2007 Einstien finals, you'll see our 6wd robot that is only driven on the rear 4 wheels playing defense quite nicely. And if you watch the Florida Regional finals of 2008 you'll see our 6wd robot with only the 2 center wheels driven do quite nicely as well. I think the key of 6wd is keeping the CG on those center wheels - or at least over the set of 4 that are driven. You also need to lower those center wheels at least 3/8". I think you should drive all 6 when you can't consistently balance the majority of your CG over the driven wheels. But if the bulk of your cg is consistently on your rear set of wheels, driving the front set won't help much. The magic of 6wd is only (1) of (2) sets of square wheel patterns on the floor at any time, vs a rectangular linear 4 wheel pattern adding drag during turns.
www.179swampthing.org
