Go to Post I wouldn't want to face THAT bad boy in competition... - Iain McLeod [more]
Unread 22-01-2011, 00:40
Re: DLink 1522
Originally Posted by Daniel_H View Post
so, I just need to configure the radio as says on the manual and have my passphrase "1156WPAKEY"?
When you're done configuring it, you will be running in Access Point mode. The passphrase in the instructions is for Bridge Mode, which you won't be using until you configure the DAP at a competition event. I think the passphrase shown is just an example, and the actual passphrase will be set for you by the configuration kiosk software.
I can imagine it working while on driver station mode, but how about during the developing code period where we don't use the driver station software?
Will you be using the Classmate to do your software development? If so, no problem. Otherwise, either connect your development computer to the "1156" wireless network or plug it into the router directly.
btw, I wish I could test this stuff by myself and save you the time of answering these elementary questions, but today we managed to burn our kOP's router (220V outlets and my careless apprentice..) and we're having a hard time finding an identical one here in Brazil.
It is possible, indeed likely, that you only fried the power adapter, and the DAP is still perfectly okay. If that is the case, you should be able to power it from the robot as intended.
Unread 23-01-2011, 10:28
DGH DGH is offline
FRC #3284
DGH is an unknown quantity at this point
Re: DLink 1522
Originally Posted by Alan Anderson View Post
The manuals indeed say nothing regarding last year's router. That's because last year's router is not used this year.
we were planning to use last years bridge instead of the d-link. is that allowed?
Unread 23-01-2011, 14:06
Re: DLink 1522
No, see <R52>.
Unread 24-01-2011, 16:34
jeleser's Avatar
jeleser jeleser is offline
AKA: Justin Eleser
FRC #2080 (Torbotics)
jeleser is just really nicejeleser is just really nicejeleser is just really nicejeleser is just really nice
Re: DLink 1522
Originally Posted by Mark McLeod View Post
The D-Link must be in AP mode to connect to the Classmate.
10.15.29.5 is correct for your Classmate/Driver Station.
Try it with security turned off.
Alright, so we can't get past the step where you change your settings in bridge mode. I know your post is pretty straight-forward, but I just wanted to double check that we in fact do not need bridge mode? Because when we try to change the settings in IE, it saves the settings for Wireless, but not for Network.
Tl;dr: We can just get away without setting up bridge mode?
Team 2080 Torbotics
2010- General build, Pit scouting
2011-2012- Electronics/Programming, Driver
2013- Electronics/Programming, Drive Coach
Unread 24-01-2011, 16:55
Re: DLink 1522
You won't be using your DAP as a bridge until you go to a competition event. If things go as I expect them to, there will be an automated "FRC Radio Kiosk" that will set up everything for you.
How do you know it isn't saving the settings? If it's just a matter of failing to show you a confirmation screen, that's easy to explain -- you've just changed the DAP's address, but your computer is still trying to connect to the original address.
You don't need to set up bridge mode for development at home. You won't be using it that way (unless you do some fancy undocumented networking setup using other equipment that might work okay but is neither supported nor sanctioned this year).
