Go to Post Six robots no one has ever heard of playing the finals on Einstein field. That's my dream matchup. - Tetraman [more]
Unread 20-01-2011, 21:08
jault jault is offline
FRC #1652 (LakeView Legends)
jault is an unknown quantity at this point
CAMERA CODE HELP!!
Hey guys i was wondering if anyone knew how to get the camera feed on the dashboard?? the camera worked fine last year with the following code
AxisCamera.getInstance().writeResolution(AxisCamer a.ResolutionT.k320x240);
AxisCamera.getInstance().writeBrightness(0);
but this year it does not work. Whenever this camera code is put onto our robot, nothing happens, and the drive does not work either. it totally kills the code.
any suggestions??
team 1652
Unread 20-01-2011, 21:21
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: CAMERA CODE HELP!!
Make sure you have
AxisCamera camera = AxisCamera.getInstance();
in your constructor. Otherwise, you're not actually initializing it.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 21-01-2011, 00:36
dirienzo dirienzo is offline
AKA: Nick DiRienzo
FRC #0011 (MORT)
dirienzo is a splendid one to beholddirienzo is a splendid one to beholddirienzo is a splendid one to beholddirienzo is a splendid one to beholddirienzo is a splendid one to beholddirienzo is a splendid one to behold
Also, make sure there is an account on the camera with a username of "FRC" and a password of "FRC" (without quotations for each). Apparently you couldn't have a feed without that account last year as well. I just found out, and now we have a working feed. Time for bed now.
Unread 21-01-2011, 22:46
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
We are also having trouble with getting the camera to show on the dashboard.
For configuring it do we need to change the subnet? or router IP?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 21-01-2011, 23:57
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
any suggestions??
team 1652
make sure the camera is connected.
if the camera is not connected it causes the system to crash.
I ran into this every time i removed the camera from the system.
as was said before, get the Axis Cam utility and add an admin username: FRC pass: FRC.
also check out this response from NI
http://decibel.ni.com/content/docs/DOC-9552
Unread 22-01-2011, 18:03
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Also, note that when you call "getInstance" of the AxisCamera, it initializes and returns a class the first time you do this. If you don't capture this class in a variable and keep it "alive" during the whole of your robot's run, it will get garbage collected and the thread it creates to relay information will be killed.
Unread 23-01-2011, 10:38
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
This is not true. AxisCamera.getInstance() will create a new instance of the AxisCamera class and return it the first time it is called. Any time after that, it returns the one instance that it already created. There is no destructor that kills the camera thread, and a reference to the singleton AxisCamera instance is always stored within the AxisCamera class in AxisCamera.m_instance. A call to AxisCamera.getInstance() will always return this instance.
public class AxisCamera implements ISensor{
    private static AxisCamera m_instance = null;
    public static synchronized AxisCamera getInstance() {
        if (m_instance == null) {
            m_instance = new AxisCamera();
        return m_instance;
The constructor calls the AxisCameraStart function that is part of the C++ library. That function starts up the PCVideoServer. Even if there was destruction of the AxisCamera object, it would not signal this thread to stop.
To get back to the original question:
Make sure the camera is configured per the instructions located here: http://www.usfirst.org/uploadedFiles...our_Camera.pdf
If there is any console output that you see before the program stops, posting that may be helpful.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 24-01-2011, 03:25
EdenA EdenA is offline
Programmer & Driver
AKA: Anthony Eden
FRC #1540 (The Flaming Chickens)
EdenA is an unknown quantity at this point
Don't try to adjust any camera settings from your code. Do all of your setting adjustments by going to the camera's webpage by connecting directly to it with your computer. The reason I say this, is because from my experience this year WPI Lib's camera parameters code is broken and crashes if you try to adjust any parameters.
In other words, try using just one line of code for streaming images from the camera:
we've only had success this year with streaming images from the new camera by doing this.
