Go to Post This is an Internet forum- if you want to relax, sit next to a pool and sun bathe. However, the rest of us will have a mature discussions and debates on the CD forums. - MikeDubreuil [more]
Unread 22-01-2011, 22:11
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
pic: burnt up TETRIX motor
Unread 22-01-2011, 22:14
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: pic: burnt up TETRIX motor
Thanks for the info. I would advise all teams not to continuously run these motors, at speed, when at the top of the pole. They will burn out. It might be wise to design a cutoff for your minibot when it hit the top. This bit of forethought will save many teams 30 - 60 bucks.
Unread 22-01-2011, 22:52
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Very interesting!
We were just messing around today and thought we burnt out one. But the weird thing was when we plugged it back into the battery without any load, it ran just fine, so much so we mounted it back on and used it for another 5-7 trials.
This is a very good tip though! This will make prototyping much less expensive!
Unread 22-01-2011, 23:03
human
AKA: Colin Nobles
FRC #0148
yes we are planing on shuting it off but a slip of the hands and boom motor gone
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 22-01-2011, 23:10
blackiceskier's Avatar
blackiceskier blackiceskier is offline
ziggy!!!
AKA: josh T
FTC #3041 (URSA MAJOR)
blackiceskier will become famous soon enoughblackiceskier will become famous soon enough
Send a message via AIM to blackiceskier
Coming from a FTC member before disassembling a DC motor from the kit plug it back in to a power source with no external load. Sometimes the motors smoke and we think they are burnt out but they just smoke and are still usable in 3 years we have gone through 3 motors actually burning out, and that was only from a 1:27 gear ratio on last years shooter for Hot Shot.
Unread 22-01-2011, 23:21
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The part that failed is the cylinder-ish one in the back, right? The blue blob is a shunt capacitor I think. It tries to reduce the brush noise on the power input line. If that shorts, you will blow a fuse every time. The smoke some others mention may also be from the part that failed here; just on the verge of failing.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 22-01-2011, 23:31
human
AKA: Colin Nobles
FRC #0148
yes the resistor is very burnt up and cracked right in half
the shunt capacitor looks fine
Unread 23-01-2011, 00:20
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Hypothetically, if one were to install a wire in parallel with the resistor, without making any modifications to the motor, <R47> would not stand in the way.* Since I don't have the motor in front of me, I can't say whether this would actually be possible: in all likelihood it would involve laparoscopic surgery through the vent holes (if any), and wrapping a shunt around the leads.
Perhaps that's not what FIRST intended...but wrapping a wire around a lead is no more a modification than wrapping a chain around a sprocket. Of course, irrespective of what the rule says, it's unlikely that FIRST would give its blessing to this technique if you inquired about it in the Q&A.
In any event, I wouldn't recommend doing this. In fact, I only bring it up because it would be a plausible explanation to give an inspector checking the resistance at the motor terminals. (Not that such checks are common practice.)
*Sometimes you just need to think like a criminal....
Unread 23-01-2011, 00:27
vincentkee vincentkee is offline
FRC #0687
vincentkee is an unknown quantity at this point
Does anyone have problems with the tabs of the motors frequently breaking off?
We have our minibot climb up a steel pole that doesn't have a top so it falls down. We don't always catch it and then the tabs of the motors keep breaking, rendering them useless unless we solder on replacements.
Unread 23-01-2011, 01:41
FRC #2170
Zip tie the leads to the motor body to give some strain relief? Solder is not mentioned in <R92> nor are electrical connectors. I hope this is an oversight. I'm not looking forward to trying to get a wire nut onto those tabs.
Unread 23-01-2011, 08:07
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Has anyone experimented with the use of a 10A fuse in place of the 20A "default" fuse? Haven't seen it discussed elsewhere.
As long as the fuse survives the inrush current, it appears that it should hold during a "normal" climb using two motors near the max power operating point, yet still open reasonably quickly once a locked rotor condition occurs. Perhaps this would have prevented the OP's issue altogether - or maybe not.
Our plan was to do this during build season, then revert to the 20A fuse for competition (and even then, replace that fuse every few matches). The worst-case scenario *seems* to be that there might be a lot of nuisance fuse openings, but it would be far less expensive to replace fuses than motors.
Last edited by ayeckley : 23-01-2011 at 08:09. Reason: Tied the logic back to the OP.
Unread 23-01-2011, 08:29
FRC #2170
Sounds like a good idea in light of the OP's situation. I've blown one 20a so far but I'm presuming that Colin's failure was with the same fuse in place. Also interesting to note that "fuse" is not mentioned in the minibot rules section.
Unread 23-01-2011, 09:26
human
AKA: Colin Nobles
FRC #0148
my electrical people said a fuse would take to long to blow as the resistor or inductor was gone in under 2 sec
Unread 23-01-2011, 10:57
Al Skierkiewicz Al Skierkiewicz is online now
The "resistor" is an inductor. Opening the motor is a illegal modification and it pretty much screws up the brush assy if not done carefully.
<R93> Motors may not be modified with exceptions of those in Rule <R47>.
A 5 or 6 amp fuse in line with each motor might be a good protection. If installed properly with insulation, etc., I do not see any rule that would prevent it. The stall current on the motor is listed at 7 amps I believe.
Unread 23-01-2011, 11:21
human
AKA: Colin Nobles
FRC #0148
Al why do u think it is a inductor? just to quiet the brush noise?
also any idea on value of the inductor?
