Go to Post West Coast Drive is best coast drive. - [more]
Unread 19-01-2011, 18:22
TJ Cawley's Avatar
TJ Cawley TJ Cawley is offline
THE Freshman
FRC #1108 (Panther Robotics)
Team Role: Driver
TJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the rough
Team Update, Rule #66
i was watching the Q & A and the GNC was asked how many tanks we can use to hold air. they responded by saying look at update 2. my question is, can someone ask how many tanks since the team update does not specify. and i quote
"<R66> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2011 FRC ROBOTS include the following items. All included items must be “off the shelf” COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi and burst pressure of 250psi, and used in their original, unaltered condition (except as required for assembly with other components).
A. Pneumatic pressure vent plug valves functionally equivalent to those provided in the KOP,
B. Solenoid valves with a maximum 1⁄8” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints).
C. than 125psi rating mandated above are permitted, however if employed, an additional pressure relief valve must be added to the low pressure side of the main regulator. The additional relief valve must be set to a lower pressure than the maximum pressure rating for the solenoid valve.
January 14, 2010
D. Additional 0.160” inside diameter pneumatic tubing functionally equivalent to that provided in the KOP, with the pressure rating clearly factory-printed on the exterior of the tubing,
E. Pressure transducers, pressure gauges, and connecting fittings,
F. Pressure regulators with a maximum bypass pressure of no more than 60psi,
G. For the purposes of the FRC, a device that creates a vacuum is not considered to be a pneumatic device and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules). These include, but are not limited to; venturi-type vacuum generators and off-the-shelf vacuum devices (as long as they are powered by provided or permitted motors).
H. For the purposes of the FRC, closed-loop COTS pneumatic (gas) shocks are not considered pneumatic devices, and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules).
I. For the purposes of the FRC, air-filled (pneumatic) wheels are not considered pneumatic devices, and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules). J. Pneumatic cylinders. K. Pneumatic storage tanks."
"To create a world where science and technology are celebrated... Where young people dream of becoming science and technology heroes"-Dean Kamen
This should start each year by focusing on worldwide issues, and having a game that, in theory if not practice, will help fix or compromise a solution with those issues, to make a better, safer worldwide and FIRST community.
Unread 19-01-2011, 18:27
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: Team Update, Rule #66
We read that to mean you can have as many aproved storage tanks as you like.
Unread 19-01-2011, 18:42
TJ Cawley's Avatar
THE Freshman
Team Role: Driver
but if you build your robot to do everything with an enormous air supply, then close to build this FINALLY gets decided, and it gets cut down to the usual 4, or even worse one, you either try to redesign the bot because of that or you just go out to the competition with a scurry bot
Unread 19-01-2011, 19:24
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You appear to be biased by prior year's rules limiting the number of tanks to 4 and not reading what the rule actually says.
In addition to the items included in the KOP, pneumatic system items specifically permitted on 2011 FRC ROBOTS include the following items.....
K. Pneumatic Storage Tanks
This means that any pneumatic storage tank that costs less than $400, is rated to 125PSI working and 250PSI burst, and physically fits inside the robot starting volume constraints may be used. You may use as many as you can fit in your budget or on your robot, whichever is less.
Unread 19-01-2011, 19:35
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
We had air compressor equipment in the Air Force which featured air storage tanks as structural elements. Wondering now if Bimba makes tanks with flanges and brackets. Probably not a good idea to weld to any of them, right?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 19-01-2011, 20:19
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Here's the latest from the GDC on the Q&A forums:
You may use any unmodified COTS storage tank as long as it meets the requirements defined in Rule <R66>.
http://forums.usfirst.org/showthread.php?t=16391
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 23-01-2011, 13:49
TJ Cawley's Avatar
THE Freshman
Team Role: Driver
but what if they do regulate it and you overuse pneumatics? the risk is yours, but i started this so someone eligible to post in the Q & A could ask seein as im not an 18 year old member. we want to know HOW MANY tanks we can use, seeing as it is not revealling
Unread 23-01-2011, 14:07
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
If we ask we will get the same answer as you got!
You can use as many as you want as long as it fits the specs Vikesrock mentioned.
Jon
Unread 23-01-2011, 14:10
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Then you have every right to be angry with them for capriciously springing a new rule on you late in the build season.* That's a risk with anything: they could lower the permitted bumper weight to 15 lb (like it used to be, in at least one previous year) on ship day. But why design for that possibility when they've explicitly said otherwise?
*FIRST usually knows better than to do things like that....
Unread 23-01-2011, 15:51
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
It seems that the rules allow for a theoretically unlimited amount of Air Tanks as long as they do not violate any other rules.
If you're truly afraid that this may change, then let me propose this solution:
Design your robot to work with 4 Air Tanks and a compressor as allowed in previous years, then add as many air tanks above the 4 as you want to allow for a greater amount of stored air. If the GDC comes out later on during build or competition season and reduces the amount of air tanks allowed on the robot then you'll be able to run with the new limit (assuming the GDC would go down to 4 tanks sized like previous year's tanks) because you designed to work with that minimum.
-Dustin Benedict
Unread 25-01-2011, 02:42
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Team 2484 asked about the maximum number of storage tanks. This just in from the GDC on the FIRST Forums:
Team Update #2 makes doesn't give a limit to the number of pneumatic storage tanks a team can use. This makes it sound like teams can use an unlimited number of storage tanks on the hostbot. Is this true?
GDC: Correct, there is no explicit limit on volume of stored air permitted on the ROBOT.
Unread 26-01-2011, 18:09
TJ Cawley's Avatar
THE Freshman
Team Role: Driver
thanks. that is what i was wondering. i didnt want our team overloading on air before this was speicified.
Unread 28-01-2011, 15:49
madgokart madgokart is offline
FRC #1518
madgokart is an unknown quantity at this point
Exclamation Re: Team Update, Rule #66
i have a question about the motors..........i was wondering if we can use them this year?
2011 motors part number-AM802-001A
PM25R-45F-1003
12VDC PM25R
101810
2010 motors part number-FR801-001
12-VdC
100807
LEGIT
Unread 28-01-2011, 16:09
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
By the way, TJ, your lead mentor (and any assigned alternate) has access to your team's Q&A login and password via their TIMS account. They login and its on one of the very first pages. That way your team can ask any questions it needs to, and you don't need to rely on Chief Delphi members for answers from the GDC.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 28-01-2011, 17:34
PM25R-45F-1003
12VDC PM25R
101810
12-VdC
100807
Check <R45-C>, as amended by Update #1. I see two part numbers in there that exactly match the ones you provided here. Therefore, they are exceptions to <R46> and may be used in competition.
