Go to Post Question: How can you tell the difference between an engineer and a programmer? Answer: You ask them to count. Engineers start counting from 1. Programmers start counting from 0. - Ed Law [more]
Unread 23-01-2011, 12:43
Cactus_Robotics's Avatar
Cactus_Robotics Cactus_Robotics is offline
Driver Development & Drive Coach
AKA: Adam Shroyer
FRC #0498 (Cobra Commanders)
Cactus_Robotics is a jewel in the roughCactus_Robotics is a jewel in the roughCactus_Robotics is a jewel in the rough
Send a message via AIM to Cactus_Robotics Send a message via Yahoo to Cactus_Robotics
pic: 2011 Team 498 Robot
Unread 23-01-2011, 12:46
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: pic: 2011 Team 498 Robot
mad Props
all the framework is there.
The team will have plenty of time to code, practice driving, and perfect your mini-bot.
Unread 23-01-2011, 12:47
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
How does it score?
Unread 23-01-2011, 13:02
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I like the pneumatics mounting that is looks really good.
How long do wires to the power distribution board have to be? It seems like an odd place for it because I don't see how you will mount your battery near it.
Unread 23-01-2011, 13:37
AKA: Adam Shroyer
Scoring will be a arm that the students were finishing sat night. Pics to follow in a few days. The lower tier is dedicated for the mini bot deployment system. Also 90% Of wiring is already completed.
Cactus Robotics, We Drive It Like We Stole It!
2001 Team Spirit Award - Southern California Regional
2004 Sportsmanship Award - Arizona Regional
2004 Regional Finalist - Arizona Regional Thanks (Team 696 & 80)
2005 GM Industrial Design Award - Arizona Regional
2007 Rockwell Automation Innovation in Control Award - Arizona Regional
2012 Regional Finalist - Arizona Regional - Thanks (Team 2486 & 4146)
Unread 23-01-2011, 13:41
AKA: Adam Shroyer
the battery will be mounted on that front plywood plate. They were drilling the batterybox mount holes when I took this pic.
Unread 23-01-2011, 13:51
whackedwatchdog whackedwatchdog is offline
FRC #3224 (LHS)
whackedwatchdog is a jewel in the roughwhackedwatchdog is a jewel in the roughwhackedwatchdog is a jewel in the rough
I'm curious, in the final design, will you be using only two CIMs for your drivetrain? Will the other two be used (needed?) for the arm? Looking at the picture (the angle makes it a little difficult to tell), it looks like only the front (I guess?) wheels are powered, are you leaving the omni wheels unpowered? If so, why?
Unread 23-01-2011, 14:19
AKA: Adam Shroyer
we are using four cims for drive and using the toughboxes all four wheels are chained. The arm will be using 2 window motors linked together to allow the arm to stay in place and 2 pneumatic cylinders for arm extension and control
Unread 23-01-2011, 14:24
FRC #3224 (LHS)
That sounds great, then, and clears up the only confusion that I saw. Thanks!
Unread 23-01-2011, 14:29
cmass cmass is offline
FRC #1189
cmass is an unknown quantity at this point
CG looks a lot higher than I would like.
Unread 23-01-2011, 14:50
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
its nice to be able to compare... Right now our teams seem to be in similar stages. Solid design. Is everything hand welded and cut?
Spartans, Prepare for GLORY!
Unread 23-01-2011, 15:06
AKA: Adam Shroyer
Yes. All cut and welded in a fellow mentors garage. The tower is actually made from a thin grade stainless steel. Ended up being lighter and stronger than a thicker grade aluminum.
Unread 25-01-2011, 00:51
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
Really? News to me
They are gonna be long when all is said and done. No big deal, nothing a couple of hypress barrel splices can't take care of.
Unread 25-01-2011, 09:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Out of curiosity, have you done some tests with the window motors? They have a nasty tendency to lose torque quickly when they warm up, and their plastic worm gears tear apart quite readily. We used one to move our 36 inch arm last year and it broke several times.
