Go to Post Can we just get over this inane lawyering of the rules and get back to building robots? . - dlavery [more]
Unread 15-01-2011, 16:21
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Peragore is an unknown quantity at this point
make66488.sh: g++: command not found andWindRiver\workbench-3.0\x86-win32\bin\make.e
Very new at this, but i am getting the above error message when i try to run any type of code. I assume it means I am lacking a program, but i have not been able to find what.
Problems:
WindRiver\workbench-3.0\x86-win32\bin\make.exe: *** [Chester_Code_example/Debug/Objects/Chester_Code_example/code.o] Error 127
\AppData\Local\Temp\make66488.sh: g++: command not found
Unread 15-01-2011, 16:40
PatrickS's Avatar
PatrickS PatrickS is offline
I get my code from /dev/null
FRC #1742 (Shockwave)
PatrickS is an unknown quantity at this point
Re: make66488.sh: g++: command not found andWindRiver\workbench-3.0\x86-win32\bin\mak
Make sure that g++ is added to the Path variable. Look here.
Unread 23-01-2011, 14:32
Peragore's Avatar
CEO of Black Magic
AKA: Philip Mulford
Getting the error, trying to fix the path, but can only find the uninstall file
Unread 24-01-2011, 17:25
rgkroker rgkroker is offline
FRC #2557
rgkroker is an unknown quantity at this point
I am a mentor working with team 2557. we are having the same problem. We are using cygwin, and have installed Wind river workbench and the labview cRio drivers. We have updated the path to include the cygwin/bin directory. Still the make fails at the g++.exe command. We installed it on five different computers with the same result.
We are running WinXP SP3 on all the machines.
Can you tell us how your system is setup? Please list the install steps you took to get Wind River working.
Unread 29-01-2011, 14:23
Peragore's Avatar
CEO of Black Magic
AKA: Philip Mulford
looks like the install disc for this year did not come with the windows version of the GNU Compiler, or G++, only the uninstall file. Aaargh!
Edit: this was not the case. We eliminated all vestiges of Windriver from the computer, and then completely reinstalled. this seemed to clear it up.
