Go to Post I don't just participate in FIRST, and it’s not part of my life. FIRST is my life. - sciguy125 [more]
Unread 23-01-2011, 15:54
sithmonkey13's Avatar
sithmonkey13 sithmonkey13 is offline
AKA: Nathan
FRC #1178 (DURT)
sithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to all
2011 Autonomous Coding Problem
We (FIRST Team 1178) have tried several times to get the autonomous line tracking to work, but every time we run code (either default or changed), the robot runs for about 2.3 seconds (we timed it) or less, and then gives a watchdog error. Has anyone else had this problem, or do you know a way to fix the problem?
Note: You cannot tell the difference between "OK Go" and "OK No" when there 2 walls between you and the robot. At that point, the only thing between injury and safety for the mechanical guys is their ninja skills.
Unread 23-01-2011, 20:47
Re: 2011 Autonomous Coding Problem
The default code doesn't use the watchdog this year. If you added it to the code, you need to feed it. You may need to measure how often you are feeding it and compare that to the timeout.
If you are talking about the safety error, it means something similar, which is that your code hasn't updated the motor often enough.
Greg McKaskle
