Go to Post Am I just a freak? - Josh Hambright [more]
Unread 23-01-2011, 16:30
neaanopri neaanopri is offline
FRC #1389
neaanopri is an unknown quantity at this point
Post 80/20 sliders
I'm from team 1389 and I'm wondering if there is anything sold which slides inside the grooves in 80/20. Our team would like to use this slider, if it exists, for our manipulator. We tried using the KOP sliders, but they have such diffucult dimensions that it is impossible to CAD them, plus they add weight while 80/20 is already a structural material. Thanks a lot!
Unread 23-01-2011, 16:57
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Re: 80/20 sliders
Indeed there is- an entire chapter's worth in their catalog, which you can view here: http://8020.net/Catalog-Intro.asp
And here are some pictures of their linear bearings in various uses, also on 8020.net: http://8020.net/Solution-8.asp
Just make sure you order the right parts!
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 23-01-2011, 17:36
EricH EricH is online now
Re: 80/20 sliders
Contact team 357, or look at their article in the 2007 Behind the Design book. They molded a custom 80/20 slider that worked pretty well. It's purely inside the grooves.
Unread 23-01-2011, 17:43
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: 80/20 sliders
You can also machine your own sliders out of Delrin on a milling machine.
Art Dutra IV
世上无难事,只怕有心人.
Unread 23-01-2011, 19:25
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Re: 80/20 sliders
If you have the capabilities I suggest you do this. The sliders from 8020 are very expensive ($40+ a piece). Plus it sounds cooler if you can say "ya we made these custom sliders ourselves".
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 23-01-2011, 20:02
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Re: 80/20 sliders
Pages 500-531 have everything you need.
Our team is using lots of 6730's. They are almost frictionless. Hope that helps.
Unread 23-01-2011, 20:20
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Re: 80/20 sliders
Slightly more friction than other methods but definitely cheaper: We discovered this week that #35 chain can be "threaded" between two pieces of 8020, and can provide a rather smooth movement between them. We're investigating using a 4' tall piece of 8020 as the lifter track, and mounting a 1' long piece of 8020 to the chain, which would serve as the mount for the tube handler. By looping the chain around a pair of sprockets, we can pull the chain and move the mount almost 4' up or down.
Picture will follow if it works.
"It's NOT Just A Robot Thing!"
Unread 23-02-2011, 14:59
ktress357's Avatar
ktress357 ktress357 is offline
FRC #0357
ktress357 is an unknown quantity at this point
Re: 80/20 sliders
Hi, I'm from team 357 and we did just this in 07. We molded a custom slide which we called jester glide. If you contact my team I'm sure we may be able to help you out.
Unread 23-02-2011, 20:48
Jstack14 Jstack14 is offline
Team Role: CAD
Jstack14 is infamous around these parts
Re: 80/20 sliders
Though it is too late our highschool got a mill this year and we designed and milled our 80/20 slider. For us, it takes a little while to make one, but it is awesome to say we created our own. They are made of delrin and they work fantastically!
