Go to Post Well I have to admit, most of the people on our team are geeks. I think that it's a title of honor considering it might as well be "boss" or "head supervisor" or something along those lines. - Cyberguy34000 [more]
Unread 23-01-2011, 15:37
Rwaas Rwaas is offline
AKA: Ryan
FRC #1138 (Eagle Engineering)
Team Role: Electrical
Rwaas is an unknown quantity at this point
Problem with Photoswitches
I have the three photoswitches mounted face down with the lenses 5 inches above the ground. They are not reading the gaffer's tape but was reading some regular black duct tape before. Anyone know what's happening or have a similar issue?
Unread 23-01-2011, 16:01
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: Problem with Photoswitches
Have you tried adjusting the thresholds of the sensors with the screwdriver adjustments? They are working fine for us with the standard FRC carpet and GRAY Gaffers tape.
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
I tried them last night. Reading straight down was my problem. Mounting them at an angle to the ground (45 degrees or so) and they worked like a charm at multiple heights.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 23-01-2011, 16:44
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
And remember the tape is GRAY not the usual black Gaffers tape.
Unread 23-01-2011, 16:46
JC,
Is the tape you are using the shiny gaffer's tape? Some highly reflective tapes may not sense as well as others. the fact that you can sense with the snesors pointed away indicates that reflection may be a problem for your tape.
Unread 23-01-2011, 17:58
JCharlton's Avatar
AKA: JC
JC,
Funnily enough we couldn't find any gaffers/duct tape in the shop. This was with regular electrical tape more to test the wiring. Reflection undoubtedly was the problem.
That said, I was impressed with how well the sensor would detect a single stripe of electrical tape at 6" or more. Calibration is easy too.
Unread 24-01-2011, 12:10
AKA: Ryan
Thanks, pointing the sensors at an angle helped a lot. And yes, we are using the black gaffers tape since that was all we could find. As long as the tape is darker than the carpet color things should go smoothly correct?
Unread 24-01-2011, 13:38
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
At least in visible light the gray gaffers tape is LIGHTER than the carpet color.
Unread 24-01-2011, 15:15
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Were testing ours at 4 inches high and using standard duck tape. This is working enough for the software team to write the code needed. We'll just have the sensors easy to get to so we can adjust them at our practice feild or at competition.
