Go to Post Start up the rumor mill... - frcguy [more]
Unread 23-01-2011, 16:34
will_1359 will_1359 is offline
FRC #1359
will_1359 is an unknown quantity at this point
Robot going backwards!
I've put the line tracking code into my robot, but it keeps going backwards whether I invert the motors or not. Could this be because it uses arcadeDrive while the rest of my code uses tankDrive? If so, how can I fix it? If not, what else could it be and how can I fix it?
Unread 23-01-2011, 16:43
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: Robot going backwards!
You should use the drive(speed, curve) function, since a joystick isn't actually being used in the tracking code.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 23-01-2011, 16:52
FRC #1359
Do you mean that I should be able to use the arcade drive thing anyway? Or do I need to change that?
Unread 23-01-2011, 17:00
AKA: Brad
#0190 ( Gompei and the Herd)
Are you sure that removing the code to invert the motors didn't change the robot direction? You can also change the sign of the computed robot speed in the code and that should also flip the direction.
The use of the arcade vs. tank functions don't stick, they just set the speeds at that moment based on the parameters passed.
Brad Miller
Robotics Resource Center
Unread 23-01-2011, 17:05
FRC #1359
I tried inverting the motors, and I tried changing the sign. Neither one worked.
I didn't think that the use of arcade vs. tank would matter, but I wanted to make sure.
Do you have any other suggestions?
Unread 24-01-2011, 02:33
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
If you are changing each of these things (only one at a time, I hope, since changing both would double negate and wind back up where you started), then perhaps we need to consider that you are changing the code in the wrong place. Can you post the code you're using and note where you and making these changes?
-Joe
