Go to Post We could not make weight so we got rid of the cRIO. - Mike Copioli [more]
Unread 17-01-2011, 20:33
sithmonkey13's Avatar
sithmonkey13 sithmonkey13 is offline
AKA: Nathan
FRC #1178 (DURT)
sithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to all
Holonomic Drive in Auton
Hi everyone, I have a question about the Autonomous Independent VI. My team is doing meccanum wheels this year, and as I fixed the default robot code (changing the drive VI's) I received no errors when I did the replacements. However when I try to build the code, I get an error and the code will not build on Auton. Ind. When I change back to regular Arcade drive, it builds.
My two questions are:
1. Do I need the Holonomic drive VI in autonomous?
2. If I do need the VI, has anyone successfully implemented it?
Note: You cannot tell the difference between "OK Go" and "OK No" when there 2 walls between you and the robot. At that point, the only thing between injury and safety for the mechanical guys is their ninja skills.
Unread 17-01-2011, 22:55
Re: Holonomic Drive in Auton
When a vi can not be run, LabVIEW will tell you what is wrong. Looking at the Autonomous Independent vi, is the "run" arrow broken? If so, clicking on it will yield a list of things that need to be fixed.
Unread 18-01-2011, 12:45
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
1. Yes you do need to have the Holonomic VI in the autonomous
2. We did it last year.
What you have to do is the same as the TeleOp where you run the open 4 motors into the Holonomic VI. But instead of having joystick input you use constants.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 23-01-2011, 16:11
AKA: Nathan
FRC #1178 (DURT)
Thanks for your help, one of our mentors helped me fix the problem.
Unread 23-01-2011, 17:16
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Just a peice of suggestion, we found it easier just to do tank drive during autonomous. It's easier to program since all you really require is to go straight and hang a gamepeice
