Go to Post Gears will win matches. Climbing will win events. Fuel will win championships. - Taylor [more]
Unread 11-01-2011, 19:28
dexo568 dexo568 is offline
FRC #3328
dexo568 is an unknown quantity at this point
usage of denso window motor
Where can we buy a sprocket that will work with the window motor coupler? OR, can someone explain other possible ways to connect the window motor with the drive chain?
Thanks, Team 3328
Unread 11-01-2011, 19:54
ttldomination's Avatar
Sunny
Re: usage of denso window motor
Thanks, Team 3328
What my team has done is taken the cone shaped outside part of the coupler and ground away some of the material. This allows a 1.125" sprocket to slide in there nice and snug. Screw in the sprocket and you're set.
Also, the output shaft is a 8mm key shaft. You can purchase this shaft from AM or another provider and use the 8mm key AM hub found here, and attach a sprocket to that.
Hope that helps,
Sunny
1648: 2013-2014
5283: 2015
Unread 11-01-2011, 22:01
DonRotolo's Avatar
Back to humble
FRC #0832
In years past we have also cut off the cone part and bolted a metal plate to the wide flange of the adapter, and run stuff off that.
Just remember that the plastic, although strong, has its limits. Have spares available and make them easy enough to replace!
Unread 14-01-2011, 23:53
vincentkee vincentkee is offline
FRC #0687
vincentkee is an unknown quantity at this point
Usage of Two Denso Window Motors on the Same Shaft
Does anyone have experience with putting two or more Denso motors to power the same shaft?
From what I heard, the Denso motors have a worm gear and are thus cannot backdrive. If you use more than one Denso motor on a shaft, since all motors vary in speeds and the Denso cannot backdrive, will the Densos end up twisting the shaft?
Thanks
Unread 15-01-2011, 00:10
KHall KHall is offline
KHall - 2171 Crown Point IN
FRC #2171 (RoboDogs)
KHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud of
Yes, we did something like that last year. We used two motors on a single shaft to form a winch that wound our kicker's spring. Worked fine.
If there was any difference in speeds, well, we let the motors work that out. The winch lasted all season and we never had issues with it.
We used spikes to drive the motors. I can't recall if we were able to use a PWM splitter cable or if (spin) direction differences caused us to need two separate PWM ports. But its probably a good idea to work out which way everything turns before you assemble it. We did blow the fuses in the spikes a couple times when the kicker locked up, but the winch just kept working.
Keith Hall
Mentor 2171
Unread 15-01-2011, 00:15
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Window motors can run backwards as well as forwards. Last year we had four window motors working in tandem to winch the robot up onto the tower. Just make sure to always run them at the same speed.
Go REX!!!
Unread 15-01-2011, 00:25
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Thanks, Team 3328
What we did to attach the coupler with the was pin it to the window motor using a cotter pin. It stayed pretty well and we never had any problems with it
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 15-01-2011, 01:32
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you have access to CNC machines (through your shop or via sponsors), you can machine your own sprockets. The Denso motors also do not like cantilevered loads, so you should always support the shaft with another bearing/bushing. Here's some 7075 aluminum sprockets with a Denso hub pattern that I machined last year for 228.
The Denso motor, sprocket, and shaft support (with Delrin bushing).
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-01-2011, 02:28
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
We turned down the included KOP hub and machined the inside to press fit a bearing that would fit over the fixed metal idler shaft on the motor (I think it was 5/16"). I drilled and tapped the end of the shaft on the motor (your allowed to modify the output shafts on motors <R47>), and held it all together with a number #10 screw and washer. You can just bolt whatever you like to the modified KOP hub. Just be careful with side loads because the metal shaft on the motor is not well supported.
We used this on our ball pinching system last year with V-belts. It was a low torque application and it never failed.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 15-01-2011, 08:11
Gdeaver Gdeaver is offline
FRC #1640
We took a 3/4" sprocket and epoxied it onto the motor. Had to ream out the sprocket hub a little. If your varying the speed of the window motor you should use a victor speed controller not a jag. If you experience random lock up remove the locking pins.
Unread 16-01-2011, 15:45
Sunny
Turns out that the output shaft of the couplers that come with the kit are not 8 mm like the Andy Mark hubs, but instead, they are about 16 mm, or about .63". Would it be wise to take a .625" AM hub and sand out the inside a bit to make it fit on the shaft?
1648: 2013-2014
5283: 2015
Unread 17-01-2011, 22:06
Team 3355 Ment Team 3355 Ment is offline
FRC #3355 (Bigg Red)
Team 3355 Ment is an unknown quantity at this point
Would you happen to have a picture of your set up?
Unread 22-01-2011, 20:53
heathput heathput is offline
FRC #2342
heathput is an unknown quantity at this point
How much are we allowed to modify the window motors/gearbox? Can we use the gearbox for another motor?
Unread 23-01-2011, 15:58
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
reference rule <R47>
Unread 23-01-2011, 17:32
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
We had success taking off the star pattern hub on the Denso shaft, using a lathe to bore out a hole in a 5/8" shaft and then "pinning" the 5/8ths shaft to the Denso shaft by drilling a hole and using a screw. I will see if I can find that setup tomorrow and take a picture. But if you have the machining capabilities sprockets like artdutra04's seem like a good way to go. Very nice!
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
