Go to Post The great thing about liking someone in your robotics team is that they've already seen you at your worst, and you cant shock them with ANYTHING anymore :D - SCROSSLEY-GCEC [more]
Unread 18-01-2011, 14:23
peter1626 peter1626 is offline
FRC #1626 (Falcon Robotics)
peter1626 is an unknown quantity at this point
Cypress Tutorial?
I have been looking around for a few hours but I cant seem to find any tutorials on how to wire and program the Cypress PSoC to use as a third joystick for the driver station. Specifically, I want to add a potentiometer and a few buttons, is this possible? If so how can it be done?
My last question is how do you program LabView to read this information?
Thanks for any help!
2010 SBPLI Long Island-Regional-Imagery Award in honor of Jack Kamen
2011 New York City Regional-Industrial Design sponsored by General Motors
2011 SBPLI Long Island Regional-Regional Winner
Unread 18-01-2011, 14:32
Re: Cypress Tutorial?
Look at the back of the Cypress board and you'll see the pins labeled that you wire your swiches and potentiometers to:
http://www.chiefdelphi.com/forums/at...2&d=1264090529
Wirewrap, a prototype board, or purchasing a special mount from AndyMark can be used to connect your switches.
There's no programming necessary on the Cypress or Driver Station.
If you look on the Driver Station I/O tab you can see if it's working and even change some of the characteristics of how each contact is handled.
In LabVIEW you check your switch settings using:
  • Driver Station Get Digital Input
  • Driver Station Get Analog Input
You'll find them on the block diagram pallete at: WPI Robotics Library -> Driver Station -> Compatibility IO
Unread 18-01-2011, 19:15
Thanks for all the help!
I have just a few more questions...
Do you need to have the 9v battery, or is the usb power sufficient?
Can you connect a LED as an indicator light to Digital Out?
I remember reading something about programing the PSoC with a FRC_IO_v2.hex, do you have to do this or did I misread something?
Unread 18-01-2011, 19:28
You do have to flash it. See How to Configure your I/O Module
Unread 18-01-2011, 22:58
You don't need the 9v battery. The Cypress board will use the battery or the USB power, not both anyway.
DO connect the Cypress board directly to your Classmate, NOT through any USB hub. It does draw a lot of power and last year a lot of teams had it drop out when match time came.
You can connect an LED to Digital out using an appropriate resistor.
Unread 22-01-2011, 18:16
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Unfortunately when I tried this today, programming failed. It said that FRC_IO_v2.hex was not compatible with our First Touch. I'm searching around here to figure out what I need to do...
Unread 22-01-2011, 21:13
Ray Gitchell Ray Gitchell is offline
FRC #0525 (SwartDogs)
Ray Gitchell is an unknown quantity at this point
Chris,
Make sure you are using a psoc 3. I am pretty sure we ordered one from Cypress, but were delivered a psoc 5. Apparently similar boards, but different processors. Thus, we are looking into the legality and compatibility of using the psoc 5, 'cause we see the psoc 3 is not unavailable. (at least the last time I checked)
Please post if you find out different, as we are getting a similar error when we try to download the latest code from FIRST for psoc 3.
Thanks, RayG
Unread 22-01-2011, 21:40
Originally Posted by Ray Gitchell View Post
Chris,
Thanks, RayG
The board we're using is the one that came in the kit from 2 years ago. Us being a veteran team, we have to reuse an old one. We haven't used any special inputs at the driver's station since FIRST switched to the NI system, so this thing has been packed away and I haven't really given it a second thought. But anyway, it is the one we got in the 2009 kit - it was just packed away and we dug it out a couple days ago.
I got the error just as we were being kicked out of the school, so I didn't have time to write it down, but it was something along the lines of this (heavily paraphrased):
"Programming failed: the XXXX.xxx was created for (something I can't remember) v32, and the (something I can't remember) you are trying to program is v31."
It seems like our board is so old that the new firmware isn't suited for it. Of course, I could be wrong. As I said, we were getting the boot as this was happening and all of that stuff is still at the school so I can't do any real testing. I'm thinking that if I recompile the open-source code with the software that I installed from the CD we had, it will solve the problem. I was hoping that someone else saw this problem and had a solution so I didn't have to spend a lot of time (which I don't really have right now) tracking this down.
Unread 22-01-2011, 23:43
No, sorry, not the same issue, although our solutions may be similar (rebuild with appropriate toolset).
Perhaps you can install the old CD on a separate computer and load the previous year's .hex file to the board.
I am afraid we may have to port the code to a variant processor, as the psoc5 uses a different compiler and probably different header files. We don't want to tear up previous driver stations, as we use them for promotions and recruiting. ;-(
Thanks for the response, RayG
Unread 23-01-2011, 04:30
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
This covers the compatibility mode I/O. Where are the extra connections for the Enhanced mode?
I am interested in the Button Inputs.
Unread 23-01-2011, 13:05
Hi Randy,
Enhanced Mode is set via the Driver Station (I/O tab -> Enhanced).
Tell it you want to use enhanced mode and what you want each pin to be.
I've attached an example that sets up 16 button inputs and shows the pin assignment corresponding to the markings on the back of the Cypress board.
Unread 23-01-2011, 18:00
AKA: Randy
Hi Randy,
Hi Mark,
I found information on the 16 DIOs. After you select the Enhanced mode, the Operator's display has the 16 DIOs plus 8(?from memory) Buttons and 8 LEDs. I think that LEDS are the tiny LEDs on the Cypress board. What I am looking for is: What are the Buttons, how do they work and how do I connect to them, if they are additional inputs?
Thanks
Unread 23-01-2011, 21:48
That information is in the Cypress Board Pinout but I don't see Button 1 called out.
In the attached, I believe the Buttons are the 5-element Slider on the board itself, and the LEDs are shown.
Unread 23-01-2011, 21:54
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
There's also a simple new product from e-stop called a CCI. It looks like a joystick to your software but gives you 12 digital inputs and 4 analog inputs. Simpler to use than a Cypress though not as flexible. http://www.estoprobotics.com/estore/...d&productId=33
Unread 24-01-2011, 02:28
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
As long as you are using the board that shipped in the kit a year ago, then the firmware should work for you. It has not been recompiled since then (no bugs reported since beta last year). If you can provide the exact error, I may be able to help you figure our what's going wrong. If I had to guess based on what you've told us so far, it would be that you downloaded a newer version of the programmer than the board supports, though I've never actually seen a complaint like that from the programmer software.
-Joe
