Go to Post ...if two good things are good by themselves let's do them both together to make a better thing. So who's up for an apple pie burrito? - Katy [more]
Unread 23-01-2011, 10:05
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
Window motor for arm
Would the denso window motors provided in the KoP handle the load of being the shoulder joint articulator for a four-bar gripper/lifter system? We are planning on using 1x1 aluminum box tubing for the structure, so how would we attatch the motor in the first place?
"Though I fly through the Valley of Death I shall fear no evil, for I am at 80,000 feet and climbing."
Unread 23-01-2011, 10:22
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Window motor for arm
This will be a non-specific answer, but will get you started.
I would use both of the window motors. They are OK on power, but they have a thermal lock out (safety feature) that can cause them to stop if they get hot. You dont want that to happen in a match.
You can get an adapter and mount a sprocket to the motor, mount the motor to your "tower" system, and then mount a larger sprocket to the arm itself. Add a chain from the motor sprocket to the arm sprocket.
Use the JVN calcluator tool if you can, to get the right combination of torque and speed. The arm rotation speed will be relatively slow compared to what the motor RPM output will be so you cannot do a direct couple to the arm.
We did something similar to this is 2007. I will get a picture today and post our arrangement.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 23-01-2011, 14:55
Joe Schornak's Avatar
Joe Schornak Joe Schornak is offline
No Stranger To Love
FRC #2840 (Blue Tide)
Joe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to behold
My team is considering using a window motor to actuate an arm mounted to a forklift-style lifter. During the course of our testing, we determined that the motor could lift a four pound weight mounted 13" from the motor axle on a simple aluminum arm. However, the motor does not actuate smoothly under this load, and rotates somewhat too quickly for fine control. We suspect that it will work better when mounted into a gearbox.
There are a number of ways to attach things to the motor, depending on how much machining you're comfortable with. You could mount a sprocket onto the plastic axle adapter thing and build a frame around the adapter to hold it all together. This method is relatively simple, but the frame might make the chain and sprocket difficult to access. It's also quite heavy, since you'll need to use a short axle with a bushing for proper support and rotation.
Alternatively, drill and tap a hole into the end of the axle, and use a bolt to hold the plastic adapter onto the motor. This is legal under <R47>A, and is much more compact than the first method. However, it requires a specific set of tools and skills, so you might want to have one of your machine shop sponsors do this for you for best effect.
As Chris said, you should consider the thermal safety lock when designing your arm. The worm gear will hold the arm at an angle without stalling the motor, but the window motors will overheat if you try to move something too heavy. My team reduced this problem by installing external cooling fans around our window motors, but they still locked up after prolonged use.
Best of luck with your robot-building!
1. Acquire Manual
2. Read Manual
3. ???
4. PROFIT!
Visit www.pcdsrobotics.org!
Unread 23-01-2011, 15:27
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
They don't back drive very well either.
So if you end a match with your arm extended you'll have to roll it back to you pit that way...or tether up to let it down.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 23-01-2011, 16:03
HarveyAce's Avatar
FRC #3329 (CAMBots)
I talked it over with my mentor, and we decided that it would probably be better to use the Banebots motor and put it on last years AM gearbox and use a chain and sprocket to lift. the question is, because we don't have a lot of materials and machines, how can we do that, because the Banebots output shaft is so tiny?
Unread 23-01-2011, 18:38
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
one of these:http://banebots.com/p/S24K-C1-7
will interface a RS 775 motor to any of the am gearboxes that ussualy mount a CIM motor.
They are also availible for the rs550 motors
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 24-01-2011, 16:29
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
We are using 2 window motors and a 9:1 sprocket setup. Given the weight of our arm and gripper, the motor should ;o) operate right in its sweet spot. But it is not built quite yet - can't tell you if the calculations were correct yet.
Best of luck!
Unread 29-01-2011, 12:13
G33k712's Avatar
G33k712 G33k712 is offline
Public Relations Manager
AKA: Garrett Dawkins
FRC #3197 (CHSR Hex Hounds)
G33k712 is an unknown quantity at this point
If our team chooses to use the window motors, is there a belt and sprocket set that works with the little gear looking shaft on the said window motor? If so, where can I find it?
Unread 30-01-2011, 01:36
At the top of page 16 of the Kit of Parts checklist is a picture of the Denso motor couplers you received. That's the only thing I know of that "works with" the motor output. You can bolt whatever you want to it.
Unread 30-01-2011, 02:00
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Adding onto this, the coupler accepts a 5/8 keyed shaft very nicely. You can also drill custom holes onto the coupler to attach a sprocket. Our team also drills and taps two channels for set screws onto the part where the coupler mates with the motor output.
Unread 31-01-2011, 23:31
Andy A. Andy A. is offline
Getting old
FRC #0095
To heap on some more detail, the 'output' shaft on the window motor doesn't rotate. That makes it pretty handy, as you can drill and tap it (carefully!) for a screw to retain the plastic coupler and whatever you attached to it to the motor. I think #10 thread works out pretty well.
Incidentally, that shaft is 8mm OD, which is close but not quite 5/16ths. Since it's advisable to avoid side loads on that shaft it's often the case that someone measures it with the intent of putting a bearing on it and finds out their brand new 5/16th ID bearing doesn't quite fit. Truly frustrating.
Unread 31-01-2011, 23:39
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
I actually designed an arm with a grabber that involves the window motor unit from the KOP. We're still tweeking and havent introduced programming to it however from small tests we've tried this seems to be a very good idea!
RHS Senior 2011
Unread 01-02-2011, 01:08
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
My team is going to use all the window motors in the KoP for the arm.
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
