Re: 80/20 sliders
If you have the capabilities I suggest you do this. The sliders from 8020 are very expensive ($40+ a piece). Plus it sounds cooler if you can say "ya we made these custom sliders ourselves".
Re: 80/20 sliders
Pages 500-531 have everything you need.
Our team is using lots of 6730's. They are almost frictionless. Hope that helps. |
Re: 80/20 sliders
Slightly more friction than other methods but definitely cheaper: We discovered this week that #35 chain can be "threaded" between two pieces of 8020, and can provide a rather smooth movement between them. We're investigating using a 4' tall piece of 8020 as the lifter track, and mounting a 1' long piece of 8020 to the chain, which would serve as the mount for the tube handler. By looping the chain around a pair of sprockets, we can pull the chain and move the mount almost 4' up or down.
Picture will follow if it works. |
Re: 80/20 sliders
Hi, I'm from team 357 and we did just this in 07. We molded a custom slide which we called jester glide. If you contact my team I'm sure we may be able to help you out.
