Go to Post I will never forget Dean's opening lines: "I want you to know that I am here under protest. I believe that everything you are doing here is repugnant and ethically wrong. And now I am going to tell you why..." And for the next 35 minutes, that is exactly what he did. - dlavery [more]
Unread 23-01-2011, 16:25
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Button programin C++
so my team is using mecanum wheels this year. we would like to make it so when you hit the trigger on the left joystick it reduces the maximum speed of the motor by half. so im my code i have this
 bool GetTrigger (Joystick hand = leftstick);
if im right that checks if the trigger on the left joystick it pushed or not.
i was trying to create an if statement to change the speed of the motors but its not working.
any suggestions?
Unread 23-01-2011, 18:33
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Re: Button programin C++
Unread 23-01-2011, 18:42
Wouldn't doubling the speed make it go faster unless you puss the trigger?
What I'm looking to do is while in operator control drive mecanum drive full power, but when you get close to the pegs you press the trigger and you drive at half the speed.
Does that make sense?
Unread 23-01-2011, 19:16
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
Unread 23-01-2011, 19:22
DiscoKittyPrime DiscoKittyPrime is offline
AKA: Joshua Bryant
FRC #0057 (Leopards)
DiscoKittyPrime will become famous soon enough
Try this:
if ( !stick.GetTrigger()){
motors.Set(x);
else{
motors.Set(x/2);
This code assumes that x is the input variable that you use for speed. For driver control, this would be the value you get from your joysticks. It works by checking to see if the trigger is pressed. If not, then the speed is just as normal. If the trigger is pressed, then the speed is half of what it would normally be. Hope this is what you meant.
Unread 23-01-2011, 19:28
That's what I ment thanks
Unread 23-01-2011, 19:35
would i put that before:
bool GetTrigger....
of after it
cause i just tried to build it and i got a boat load of errors
Unread 23-01-2011, 19:41
AKA: Joshua Bryant
If your joystick's name in the program is "hand" then the portion of the code that needs to be the argument for the if statement is as follows: "hang.GetTrigger()".
The code segment would look like
if ( !hand.GetTrigger()){
motors.Set(x);
else{
motors.Set(x/2);
You don't need a boolean variable for this code, only the value coming directly from the joystick.
Unread 23-01-2011, 19:45
it dosent like motors.set(x)
do i have to declare each motor
leftmotor.set(x),rightmotor....
Unread 23-01-2011, 19:52
AKA: Joshua Bryant
I am sorry, I forgot to mention that the "motors.Set()" section was just a stand in for whatever functions you use to move. You would either replace the "motors" part with the motors that you declared earlier in your program or replace the "motors.Set()" function with whatever function you were using to drive.
For example, if you declared your motors previously as LeftMotor and RightMotor, then the code would look like:
LeftMotor.Set(x);
RightMotor.Set(x);
else{
LeftMotor.Set(x/2);
RightMotor.Set(x/2);
Sorry about forgetting to include that little tidbit. If you have any more problems with your code, post a copy of the driver section so we can see what might be the problem.
Unread 23-01-2011, 20:00
i tried to put in left motor and other stuff
here is the code
#include "WPILib.h"
#include "Vision/AxisCameraParams.h"
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick leftstick; // only joystick
	Joystick rightstick; // only joystick
	HSLImage image;
public:
	RobotDemo(void):
		myRobot(1, 2, 3, 4),	// these must be initialized in the same order
		leftstick(1),		// as they are declared above.
		rightstick(2)		// as they are declared above.
		myRobot.SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		myRobot.SetSafetyEnabled(false);
		myRobot.Drive(0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 				//    for 2 seconds
		myRobot.Drive(0.0, 0.0); 	// stop robot
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		myRobot.SetSafetyEnabled(true);
		AxisCamera &robocam = AxisCamera::GetInstance();
		robocam.WriteResolution((AxisCamera::Resolution_t)3);
		robocam.WriteBrightness(0);
		Wait(3.0);
		while (IsOperatorControl())
			myRobot.MecanumDrive_Cartesian(leftstick.GetX(), leftstick.GetY(), rightstick.GetY(), 0); //Mecanum drice, float x,float y, float rotation, gyro
			bool GetTrigger(Joystick hand = leftstick);
			if (!leftstick.GetTrigger()){
				motors.Set(x));
		else{
			motors.Set(x/2);
			robocam.GetImage();
			image.GetImaqImage();
			Wait(0.005);				// wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
Thanks for the help sorry to be a bothersum and ask so many question this is my first time using c++
Unread 23-01-2011, 20:01
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
If you want it to toggle, (untested)
bool hasJoystickBeenClicked(Joystick &joystick, bool &prev, bool &cur) {
  prev = cur;
  cur  = joystick.GetTrigger();
  // Previous joystick value should be true (pressed trigger) and
  // current one should be false (released trigger).
  return (prev && !cur) ? true : false;
void getMotorSpeed(float &speed, bool half) {
  return (half) ? speed / 2 : speed;
void toggleHalfSpeed(bool &half) {
  half = !half;
if (hasJoystickBeenClicked(joystick, prev, cur))
  toggleHalfSpeed(isHalfSpeed);
motor.Set(getMotorSpeed(speed, isHalfSpeed));
EDIT: More code.
Unread 23-01-2011, 20:15
AKA: Joshua Bryant
Talking Re: Button programin C++
robocam.WriteResolution((AxisCamera::Resolution_t) 3);
Wait(3.0);
myRobot.MecanumDrive_Cartesian(leftstick.GetX(), leftstick.GetY(), rightstick.GetY(), 0);// mecanum drive at full speed
else{
myRobot.MecanumDrive_Cartesian(leftstick.GetX()/2, leftstick.GetY()/2, rightstick.GetY()/2, 0);// mecanum drive at full speed
robocam.GetImage();
Try this for your OperatorControl function. This should work for you. And have fun with the mecanum drive, it's alot of fun once you get used to driving it.
Unread 23-01-2011, 20:17
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
You just need to replace the motor.set() with myRobot.Drive().
Here is your code with the replacements made. It compiles.
#include "WPILib.h"
	HSLImage image;
public:
	RobotDemo(void):
		Wait(3.0);
				myRobot.Drive(1.0,0.0);
		else{
			myRobot.Drive(0.5,1.0);
			robocam.GetImage();
Unread 23-01-2011, 20:21
discokittys worked
random question for you guys, i know it is off the topic but...
why isnt my camera sending an image to my driverstation?
