Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 23-01-2011, 20:26
Re: axis 206
The "limited connectivity" indication usually just means you don't have a connection to the Internet.
Being unable to connect to the camera usually means your computer's IP address is not set to one compatible with the camera's default. Are you following the How to Configure your Camera document on the Kit of Parts web page?
