Go to Post I also exclusively use FRC team numbers when punching in times for the microwave. - Calvin Hartley [more]
  #37   Spotlight this post!
Unread 23-01-2011, 20:27
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
Re: usage of denso window motor
Originally Posted by heathput View Post
Rule <R47> talks about modifications to motors. If I understand the rule, I can remove the motor, leaving the gearbox. Then I can mount a different legal KOP motor to the gearbox. It would require an adapter, but would be legal. Does anyone think I am off base?
As long as the motors you plan to use are in accordance with rules <R45> and <R46>, it should be OK as far as I know, but I don't really see why you would want to. Furthermore, I wouldn't want to be the one to have to figure out how to securely attach a bane bots motor to a window motor gearbox.
