Go to Post a robot that is broken shows that it has survived more than a robot that doesn't even have a scratch. - robot180 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 23-01-2011, 19:51
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
axis 206
I'm having trouble connecting to the axis 206 camera i have it connected to my lap top i restored it to factory default but i cant access it there is a connection but its limited and cant access it through my web browser is there any thing i can do?
Unread 23-01-2011, 19:55
SudoSammich SudoSammich is offline
A pretty big deal...
AKA: Corey
FRC #0514 (Entropy)
SudoSammich is an unknown quantity at this point
Re: axis 206
We actually just finished the connection troubleshooting on our camera thanks to CD, can you describe the system you're using to connect? Are you using a tether or a router? How is everything else configured to obtain IP addresses? Need a bit more information before I can say anything.
Oh, and of course the camera setup guide is your best resource for EVERYTHING camera related.
Unread 23-01-2011, 20:26
Re: axis 206
The "limited connectivity" indication usually just means you don't have a connection to the Internet.
Being unable to connect to the camera usually means your computer's IP address is not set to one compatible with the camera's default. Are you following the How to Configure your Camera document on the Kit of Parts web page?
Unread 23-01-2011, 20:32
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: axis 206
Also, don't forget you need a crossover cable if connecting directly from laptop to camera.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 23-01-2011, 20:51
Re: axis 206
Most laptops will automatically switch their Ethernet port to do a crossover connection when necessary. I've never encounted a laptop capable of running Windows XP or later that doesn't do it. That includes the Classmate.
The two things in the FRC control system that do not do automatic crossover are the cRIO and the Axis camera. Wiring those items together is the only place a crossover cable is necessary.
Unread 23-01-2011, 22:13
Re: axis 206
I own one running XP , but it's pretty old.
Talks to everything I ask it to though, so I keep it around.
