#7
Re: Encoder and line tracker wiring
If you are using labview...
Take a look in the default autonomous code that is in your C-Rio project. If that doesn't provide the help you are looking for, check this tutorial out! http://decibel.ni.com/content/docs/DOC-14730 It covers the basics about line following that should be of some help to your team! GOOD LUCK -Mcgurky |
