Go to Post So when a team leader decides to give all their heart to a team, it is true love that they exhibit towards it. - Anton Abaya [more]
Unread 23-01-2011, 11:24
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Encoder and line tracker wiring
Can anyone please take a good quality snapshot/picture of how wire up an Encoder and a Line Tracker to the sidecar, and upload it to this thread or send it to my email: technoking51@gmail.com- thanks in advance
Unread 23-01-2011, 17:21
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Encoder and line tracker wiring
its basically orange to red (positive), black to brown (ground), and white to yellow/blue (signal A/B, both wires don't need to be wired) for the rotary encoder.
Unread 23-01-2011, 17:30
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Hey it would be useful if I could see this too. Is there a photo or a video of how to assemble the sensors, or any relative information?
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 23-01-2011, 18:57
FRC #1747
There's some stuff here http://decibel.ni.com/content/docs/DOC-14724
But the basic breakdown is this:
  • If the sensors gives back voltages (lookup), it goes in the analog break out.
  • If the sensors give back data (again, lookup), like numbers, it goes in the digital side car.
  • On each sensor are some letters followed by some kind of hole. These are basically different kind of data they can send back (lookup which holes send what kind of data). The essential ones though are + (power) and G/- (ground). After that, it depends on what you need.
  • The holes have to be soldered to a wire on the connection you are using
I'll try posting pics after midterms (ends on Thursday), earlier if possible.
Unread 23-01-2011, 19:23
SudoSammich SudoSammich is offline
A pretty big deal...
AKA: Corey
FRC #0514 (Entropy)
SudoSammich is an unknown quantity at this point
Ironically I did actually take a picture of the wiring for our quad encoders last year, but I lost it when I transferred phones and can't remember how we did it without our wiring diagram near me now.
As for the banner sensors (line tracking sensors included in the KOP), they're wired just a *bit* differently from everything else. Blue is ground, brown is power, and the white and black wires are "light output" and "dark output", respectively.
The sensor requires greater than the 5V of power the digital sidecar can provide for it, so you have to wire it directly into the power distribution block (big thing filled with breakers that you use the wago tool to operate, not 100% sure I've got the correct terminology here). Just put the blue into a black and brown into its corresponding red with a 20 amp breaker and it'll run fine.
As for the signal wires, you have to attach a pwm cable to the output(s) you wish to use and plug that cable into the digital sidecar. We're opting to use the light output, which reads "true" when the sensor receives a white input, so we soldered the white wire off the sensor to the white wire on a pwm cable and left the black and red from the pwm alone. This is working for us thus far, and we're just about done with our line tracking code.
Hope this helps!
Unread 23-01-2011, 19:48
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
Great! thank now i can see the line tracker working, lights are blinking, and its sensing Thanks again, but one question how did you go about prorgramming the line tracker??
Unread 23-01-2011, 20:42
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
If you are using labview...
Take a look in the default autonomous code that is in your C-Rio project.
If that doesn't provide the help you are looking for, check this tutorial out!
http://decibel.ni.com/content/docs/DOC-14730
It covers the basics about line following that should be of some help to your team!
GOOD LUCK
-Mcgurky
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 23-01-2011, 21:06
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
I have an image of the setup for the photoswitch on the following thread.
http://www.chiefdelphi.com/forums/sh...ad.php?t=89840
Hope it helps.
Unread 23-01-2011, 21:26
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
GOOD LUCK
-Mcgurky
yea, we use c++ but thanks for your help
Unread 25-01-2011, 20:48
FRC #1747
lol, its not helpful at all, but here's the pic as promised
