Go to Post One thing that FIRST has given me ... Friends who care. - Arefin Bari [more]
Unread 23-01-2011, 20:28
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
necessary torque for an arm
We've calculated that there are 51 ft-lbs of torque resisting our arm's movement. To move the arm we were thinking of running two RS-550's at peak efficiency. They would be run through a CIM-U-LATOR (2.7:1) and then a p80 (256:1) this gives us 63 ft-lbs of torque as an output.
The question is, do we then do an additional reduction to increase the torque?
The current reductions have us running at 25 RPM and we would like to stay above 15 RPM.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 23-01-2011, 20:33
Chris is me's Avatar
AKA: Pinecone
Re: necessary torque for an arm
51 ft-lbs is a pretty heavy arm...
that's 63 ft lbs at peak efficiency, right?
Also, 25 RPM is 150 degrees per second - a QUITE high arm speed.
Unread 23-01-2011, 20:39
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
The arm needs to travel about 90 degrees (it's a 4-bar linkage) so at 15 fps we're looking at one second total for arm travel. I've tried to convince the others that that's a bit too fast (I use "a bit" loosely) but to no avail. Also, the arm is still in the design stage, so I guessed high on the weight.
Unread 23-01-2011, 20:43
AKA: Pinecone
The main thing would be that it's a lot more difficult to precisely control an arm that travels over its entire reach in half a second than it would to control one going up in 2 seconds.
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Agreed. 25 rpm is way too high. We're looking at something like 10 rpm
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 23-01-2011, 20:46
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Okay, so if I add a 2:1 reduction, we'll be at 126 ft-lbs and 12.5 RPM at peak efficiency.
There's a potential problem. The p80's are rated for 85 ft-lbs max. Is this for the torque inside the gearbox, or the torque of the system?
Unread 23-01-2011, 20:48
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
That rating is the max recommended torque at the gearbox output.
Unread 23-01-2011, 20:49
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Happy Birthday!
And so that system would be fine? (mind-numbing speed aside)
Unread 23-01-2011, 20:52
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
If it's worth anything to help you judge speed:
We will be lifting a 3.5 pound arm that travels at 100 deg/sec (100 deg is full travel).
We also have options to slow it down via programming or different sprockets incase we find it is either too quick or too slow.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 23-01-2011, 21:04
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
I feel like this needs to be reduced further, perhaps with a chain. If it is that fast it will be hard to control. Anyway nice to know some other people know the Cim-u-lator exists, we were thinking of using one also because weve reached our CIM limit because of mecanum drive. But unless your arm weighs more then 40 pounds, one rs550 with a 64:1 transmission will do just fine. I've posted some videos of our team testing an rs550 the thread is here:
http://www.chiefdelphi.com/forums/sh...php?p=1006598#
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Unread 23-01-2011, 21:09
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
The way I got to the 51 ft-lbs was by figuring out the reaction forces on the two pivot points for the top bar in our four-bar linkage. The reaction force was 76 pounds, multiplied by the length of our driven bar gives us 51 ft-lbs.
Unread 23-01-2011, 21:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Please be careful giving advice like this. This statement is absolutely false.
The tests you linked to demonstrate 40 lbs on a 2" pulley which is 80 inch-pounds of torque. The original poster calculated that they need up to 51 foot-pounds of torque for their arm. That's 7.65 times more torque than the scenario in your video.
Happy Birthday!
Thanks!
Without doing the math myself, and without any formal mechanical training, the numbers you have posted seem plausible. In addition, you may be able to lower the required torque by partially balancing the arm with surgical tubing or a gas spring.
Unread 23-01-2011, 21:15
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Great advice, thanks! My main concern was with the theory being employed. I understand all the math we're using and can tweak the pivot distances to minimize the torque.
Unread 23-01-2011, 21:25
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I'd suggest some possible safety issues in addition to what has already been said. That heavy of an arm going at those speed could do serious damage to other robots. I'm all for an aggressive game, but lets not crack each others lexan.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 23-01-2011, 21:29
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
This is assuming a 10 lb manipulator approximately five feet away from the closest pivot point on our four-bar linkage.
