Go to Post "I'm not teaching you math, I'm teaching you how to think. Hopefully that'll be useful to you someday..." - Karthik [more]
Go Back   Chief Delphi > Technical > CAD
Unread 22-01-2011, 20:23
cpriese cpriese is offline
FRC #3546
cpriese is an unknown quantity at this point
Need BanBots P80 12:1 Mounting Dimensions
The data sheet on this gearbox is unclear. Can one tell me the correct mounting bolt hole pattern? Need the locations for the holes that go into the sides - not the holes with axis parallel to the gearbox shaft.
Thanks!
Unread 23-01-2011, 21:34
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: Need BanBots P80 12:1 Mounting Dimensions
If you have CAD you can go and print out your OWN! templates, PM me if you have any questions
Unread 23-01-2011, 22:27
FRC #3546
The data sheets on Banebots website are not legible and appear to be wrong. Cannot find any CAD on the internet that seems reliable. I have CAD and have made my own model to the data sheets but the mounting info is not apparent. Do you have a P80 12:1 gearbox? Looking for someone with one so the dimensions can be measured directly.
http://banebots.com/docs/P80A-DATASHEET.pdf
see page 26
Unread 24-01-2011, 08:33
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Looking at the banebot drawing on page 26, I come up up with the following for the 1/4-20 mounting holes:
Dimension parallel to the shaft axis, center to center: 2.263"
Dimension perpendicular to the shaft axis, center to center: 1.378", centered on the shaft axis. (0.689 off center axis.
These dimensions are from the "incomplete" banebot CAD drawing. We have used them in the past, but I won't physically have in hand until tonight.
PM me if these are not the dimensions you are after. Hope this helps.
Anyone else out there that wants to chime in to verify or change, please do!
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 25-01-2011, 21:06
FRC #3546
Can you veirfy the dimensions when you recieve your gearbox and post back? I'd hate to start making holes to wrong data.
Thanks!
Unread 26-01-2011, 21:57
Hodge1
Smile Re: Need BanBots P80 12:1 Mounting Dimensions
A snowstorm has locked down the school. I have an EMail out to another mentor on our team to verify the dimensions.
Sweat the details
Unread 27-01-2011, 11:55
FRC #3546
Thanks for checking. BaneBots called me back yesterday. They confirmed the dimensions you said 1.378 x 2.263.
Now the only problem is I cannot get my gearbox order till next week - best case! If you have 4 of these gearboxes laying around - I'll take'm!
