Re: Weird glitch
2. STP files shouldn't have a problem What method did you use to download Inventor? CD (not chief delphi )? off the website? Also are there any files you have issues downloading that are generic like mecanum wheels or toughbox nanos? because my CAD has those and i could post the inventor files for those on here.Good luck dude, I understand your pain w/ Inventor. But when you get it all figured out, it's one of the best programs out there. The stress tests and whatnot can prove to be very helpful |
Re: Weird glitch
STEP files do not have constrains in them. The best thing to do with them is to save them Inventor files. When you do this, Inventor will automatically create a sub folder inside your working project and will save all the components as parts or assemblies depending on what they are. Next thing you should do is open up any assembly that was derived from a step file and either ground all the components so they can't move or constrain them properly. This should resolve your links and also prevent the assembly from "exploding".
Re: Weird glitch
I actually tried installing Autodesk online but had so many issues that I ended up installing it from the CD we got from the KoP. And, I did not have any problems w/ downloading the file, but it just sometimes messes up after I place and fully constrain it and then open the assembly later.
Also, thanks for telling me about STEP files. I did not know that, and that will be helpful, but this doesn't just happen with STEP files although it happens with them often, too. |
Re: Weird glitch
long story short your team mate needs to research inventor "projects" files
to be brief inventor uses file associations to create the assembly file. think of it like this.. for purpose of example take this. (graciously donated image from this thread..)http://www.chiefdelphi.com/forums/sh...threadid=89768 assuming the chassis is one part. and the motors another, and the wheels a 3rd part each of the parts needs to be save in the same folder within someones computer "directory" or drive so that the inventor project file can reference the location of the parts in the assembly . to further simplify my suggestion is to require every part designer to save eery PART into the same folder and / or rather prior to "building" the robot in inventor to have all the parts saved (by the assembler) into the same folder as you might have guessed we've had similar problems previously |
