Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 23-01-2011, 22:52
xSAWxBLADEx's Avatar
xSAWxBLADEx xSAWxBLADEx is offline
DaBears til 13 turned Free Agent 14
AKA: Michael Hawley
no team (Free Agent)
Team Role: Scout
xSAWxBLADEx will become famous soon enoughxSAWxBLADEx will become famous soon enough
Send a message via MSN to xSAWxBLADEx
Re: Forklift Dilemma
our team is building a forklift also and we are using a pully system with wire/rope (it worked well on your '09 elevator)
Unread 23-01-2011, 23:01
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Our team is using cable with pulleys to power our forklift, we are accounting for possible slip with a limit switch and clever programming.
While it may not be the best option, it is what we think will work the best.
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 23-01-2011, 23:13
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Spectra is one option. It absolutely does not stretch. It's a polyethelene (plastic) based rope / line that many sailboat racers use in place of aradmids like kevlar due to it's high UV resistance and (comparatively) long life. It weighs next to nothing and is far stronger than steel rope. However, it does chafe and will wear through if it crosses sharp corners. It's also pricey compared to wire rope, but you can use tiny pulleys (less than 1 inch diameter).
Of course, the good old standby of cable works well too. Heavy, must have larger pulleys, but has excellent indicators of failure when strands begin to part.
Then there's chain.
You can always use chain to power the first stage, and spectra or wire for the others. That's what we did in '08.
