Go to Post I'm impressed and incredibly amused that you found so many of Dave's evildoings, though granted, they aren't that hard to search out. - DCA Fan [more]
Unread 24-01-2011, 02:28
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Cypress Tutorial?
Originally Posted by Ray Gitchell View Post
No, sorry, not the same issue, although our solutions may be similar (rebuild with appropriate toolset).
Perhaps you can install the old CD on a separate computer and load the previous year's .hex file to the board.
I am afraid we may have to port the code to a variant processor, as the psoc5 uses a different compiler and probably different header files. We don't want to tear up previous driver stations, as we use them for promotions and recruiting. ;-(
Thanks for the response, RayG
As long as you are using the board that shipped in the kit a year ago, then the firmware should work for you. It has not been recompiled since then (no bugs reported since beta last year). If you can provide the exact error, I may be able to help you figure our what's going wrong. If I had to guess based on what you've told us so far, it would be that you downloaded a newer version of the programmer than the board supports, though I've never actually seen a complaint like that from the programmer software.
-Joe
