Go to Post Above all, have fun and, if you need help, ask for it... Your inspectors will be glad to help or try to arrange for another team to help you. This should not be a traumatic experience! - Mike Betts [more]
Unread 23-01-2011, 22:18
Shaf2909's Avatar
Shaf2909 Shaf2909 is offline
FRC #2909 (Zebrabots)
Shaf2909 is an unknown quantity at this point
Exclamation Fetcher/ Help
What are the weight of the tubes?
How fast is a cim motor in a tough box?
Alex Shafer Team 2909 ( ZebraBots)
Unread 24-01-2011, 03:06
dtengineering's Avatar
AKA: Jason Brett
Re: Fetcher/ Help
This document http://www.usfirst.org/uploadedFiles...r%20Curves.pdf gives you some rough information on the motors.
Free speed is the speed of the motor, with no load... you will never get quite that high as there is always drag on the motor, from the gearbox, if nothing else. For a simple, first order approximation, say the CIM is running at 4,000 rpm, divide by your gear ratio (typically about 12:1 in a toughbox) and then multiply by your wheel circumference to get an estimate of your robot's top speed.
I beleive if you search for "JVN's Mechanical Design Calculator", though, you'll find something even more useful.
As for the tube weight, I don't have access to a KoP, so I'll leave that to someone who does.
Jason
Unread 24-01-2011, 08:06
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Fetcher/ Help
Tubes weigh between 10 and 11 ounces on average according to our scale.
-Dustin Benedict
Unread 24-01-2011, 08:15
Shaf2909's Avatar
Re: Fetcher/ Help
Thank you!
