Go to Post A good driver will always win over a good robot. - Mike Norton [more]
Unread 14-01-2011, 20:25
Prairs Prairs is offline
FRC #1610
Prairs is an unknown quantity at this point
How to invert the x-axis values?
We have been trying out our new robot but when we turn our joystick left the robot goes right and vice versa. Is there any way to invert the x values in labview so we can rectify this?
Unread 14-01-2011, 20:29
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: How to invert the x-axis values?
The answer to the question specifically asked is to multiply by a constant of -1. I believe, I am not heavily versed in this area.
If we dig deeper we might actually find the problem. Could it be fixed by reversing which wires are connected to the motor controller? i.e. swaping m+ and m-. This is not the proper solution if forwards and backwards are working correctly.
Is this default code you are running or have you done any work on it?
- Arizona North
Unread 14-01-2011, 20:35
FRC #1610
We made it so the Right and Left MotorInverted values are opposite because the robot would only drive in a circle (the two motors are opposite ways and would clash without doing this), but I don't think we changed anything else yet.
(Also, sorry if you can't understand what I'm saying exactly; I'm a newbie programmer for my team. )
Unread 14-01-2011, 20:41
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
There is a "negate" function available for this. It is a little cleaner on the BD.
Mike B
Unread 15-01-2011, 08:46
It might just be that the left and right motors are swapped. Make doubly certain that the PWM outputs you're telling the Drive Open to use match the ones actually wired on the robot. There are ways of connecting things and configuring the "MotorInverted" parameters that will give the results you are reporting.
Unread 15-01-2011, 13:59
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
As mentioned, you correct by physically swapping motor wires or multiplying the command value by negative one. For me though, the cleaner way is to look into the begin.vi where the motor definition is. You should see a boolean input to the motor definition vi that allows you to change motor direction definition.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 24-01-2011, 08:32
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
We had the same problem and it turned out that we had our "MotorInverted" parameters backwards, it's a quick fix just change the trues to falses in the begin.vi.
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
