Go to Post If you look at where you have come from you can often tell where you are going. - Turtlecoach [more]
Unread 24-01-2011, 08:39
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Problems With Classmate
When I reimaged the classmate PC, the Driver and Developer accounts did not appear. Am I supposed to make those myself or were they supposed to automatically appear with the reimage?
Unread 24-01-2011, 10:21
Re: Problems With Classmate
After the reimage you should have seen three accounts: Driver, Developer, and one you named yourself during the Windows 7 setup after the reimaging.
Unread 24-01-2011, 15:40
dmitch's Avatar
However, i didn't. Do I need to rereimage? Or what should I do to get them on there?
Unread 24-01-2011, 15:49
Does the rest of the Windows 7 install look and work as it should? If you are at all suspicious, then by all means re-image it again. It only takes 30 minutes.
You can also just create a Driver account. That's the critical one for competition.
The "Developer" account can be any other nonDriver account. It doesn't have to be named that.
