Go to Post REMEMBER - there ARE things more important than robots... false - Botwoon [more]
Unread 24-01-2011, 07:55
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
Four-bar joints
What would a cheap solution as to what to use for the axle hinges of the joints of the robot? all we have is the kop and no money... oh, and hardly any equipment... we are using the gearbox with chain to the top shoulder joint with a sprocket, with another small banebots motor for a claw. do the bane bots use jags, or could we use a spike relay?
"Though I fly through the Valley of Death I shall fear no evil, for I am at 80,000 feet and climbing."
Unread 24-01-2011, 08:00
2611.Shooter 2611.Shooter is offline
Programmer
AKA: Andrew Lavery
FRC #2611 (Vectors)
2611.Shooter is infamous around these parts2611.Shooter is infamous around these parts
Re: Four-bar joints
You can run them off of a spike. however, if you need variable speed, it may be smarter to run them off of a vector motor controller. they are cheaper than the jaguars, but still provide fine control. hope this helps.
Unread 24-01-2011, 10:03
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: Four-bar joints
Instead of purchasing bearings or nylon, you could glue in some pieces of PVC pipe. It's not quite as low friction as nylon, but with enough grease it should work!
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 24-01-2011, 10:08
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Four-bar joints
We have used tubing/bolts, etc through a hole drilled in 1/4" lexan.
For heavier joints, you can use the bolt as an axle, and use a bronze bushing in a piece of aluminum. Bronze bushings are cheap.
Unread 24-01-2011, 10:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Four-bar joints
A steel bolt going through any kind of metal or plastic or wood will probably be adequate for a pivot bearing. Make sure the hole is just a little bit bigger than the bolt, perhaps a few thousandths of an inch up to 1/64 inch bigger.
Please read the robot rules in the FRC Game Manual
http://usfirst.org/roboticsprograms/...nt.aspx?id=452
which are very specific about what device you have to use to power the motors. Some motors can be driven with a Spike relay, others require a Jaguar or Victor speed controller.
Unread 24-01-2011, 10:21
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Four-bar joints
Contact some local teams for help. I know if you were in my area we would gladly help you out with parts or what ever you may need.
Unread 24-01-2011, 15:16
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Four-bar joints
Many teams have used PVC pipes with T connectors on the ends for their arms. Inside the T connectors you will need an endcap each end that will connect the smaller diameter axle to the pipe, or a bushing to the pipe.
These can be made on a lathe, but I'm guessing you don't have one. This is the first year we have one.
Here is how we have done it in the past-
1. Buy a hole saw that's interior cutout is the size you need, or slightly larger than needed. A bit larger is likely what you will find.
2. Cut out as many of endcaps as you need from 3/4" red oak. Do not use plywood or MDF it will split.
3. Carefully line everything up and anchor each piece and enlarge the hole to the size disired.
4. Use a bolt and nut to compress the endcap
5. Put the bolt in a drill press (or properly anchored hand drill) and use a file until it is the size you would like.
Hole saws can be found at nearly every hardware store.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
