Go to Post Is it legal to build 2 robots? yes. Is it crazy to do so? maybe. - Andy Baker [more]
Unread 24-01-2011, 10:21
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Four-bar joints
Contact some local teams for help. I know if you were in my area we would gladly help you out with parts or what ever you may need.
Unread 24-01-2011, 15:16
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Four-bar joints
Many teams have used PVC pipes with T connectors on the ends for their arms. Inside the T connectors you will need an endcap each end that will connect the smaller diameter axle to the pipe, or a bushing to the pipe.
These can be made on a lathe, but I'm guessing you don't have one. This is the first year we have one.
Here is how we have done it in the past-
1. Buy a hole saw that's interior cutout is the size you need, or slightly larger than needed. A bit larger is likely what you will find.
2. Cut out as many of endcaps as you need from 3/4" red oak. Do not use plywood or MDF it will split.
3. Carefully line everything up and anchor each piece and enlarge the hole to the size disired.
4. Use a bolt and nut to compress the endcap
5. Put the bolt in a drill press (or properly anchored hand drill) and use a file until it is the size you would like.
Hole saws can be found at nearly every hardware store.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
