Go to Post Because you know what they say, the new year doesn't begin until Dean, Dave, and Woodie drop the big one. - Jay Trzaskos [more]
Unread 24-01-2011, 10:29
Revant54 Revant54 is offline
FRC #1474
Revant54 is an unknown quantity at this point
WindRiver Deployment Error
Hey everyone,
Everytime we try to deploy our sample code to the cRIO, we get an error and this is what it says in the details box: "Please set your team number and file under Window->Preferences".
Now I went to Window -> Preferences -> Team, and I haven't been able to find anything refering to the team number and file. Any advice would be greatly appreciated.
Thanks.
Unread 24-01-2011, 10:33
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Alexander Meyer is on a distinguished road
Re: WindRiver Deployment Error
The team number option will be under Preferences->FIRST Downloader Preferences.
Unread 24-01-2011, 11:00
Casual nonsense Casual nonsense is offline
FRC #1474
Casual nonsense is an unknown quantity at this point
Hi, I am the coder on the same team. Even after entering our team number here, whenever we deploy our code, nothing occurs, and no code is deployed.
I dont know how to deploy our C++ code to our robot successfully. Any advice?
Unread 24-01-2011, 12:34
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Do you power cycle the robot afterwards?
GSR Dean's List Finalist 2011
Unread 24-01-2011, 12:42
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
In the same window you typed the team number into, you also need to tell it where the code is for your project. Assuming you started with the SimpleTemplate example, click browse and direct it to C:/windriver/workspace/<Project Name>/PPC603gnu/SimpleTemplate/Debug/SimpleTemplate.out
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 24-01-2011, 21:18
FRC #1474
So after doing all of these steps and having the RIO find our file (thanks for the tip btw) It doesn't have an error when deploying. the thing is nothing happens when I click deploy. Literally nothing, the drop down menu just goes away. I then shut off the RIO and connected it to the DS and it says there is no robot code on the brain. Any advice at this point?
Unread 24-01-2011, 21:22
Jake-3284's Avatar
Jake-3284 Jake-3284 is offline
FRC #3284
Jake-3284 is an unknown quantity at this point
You're firewall is probably not disabled. Disable it and deployment should work.
Unread 26-01-2011, 18:56
FRC #1474
So we haven't got a perfect deploy. So we followed a tutorial example of using a debugger in Windriver, after the first successful run and the program terminates, I try to run again and get the following error "Download failed, possibly caused by object module already in memory". We seem to have made progress in that the Driver Station notices we have robot code on the Rio, However the code does not function and essentially the debugger can't even fully run. http://thinktank.wpi.edu/article/137
Unread 26-01-2011, 19:09
FRC #1474
We temporarily resolved the previous issue by changing the advanced download options, by unchecking the do not unload existing module box, so now when the simple robot template executes we are getting an error during the startrobottaskfunctioninrobotbase.cpp the error is "default code was still running please try again". We don't know what this means. Help?
